  #101
Old 08-12-2007, 07:35 PM
Bouncer88's Avatar
Bouncer88
Bouncer88 is offline
Default RE: What Did You Do To Your RAM Today?
Sprayed the whole undercarraige down with wd-40/brake cleaner and wiped it down.
Looks soooooooo much better.
  #102
Old 08-13-2007, 11:57 AM
rtmorrisjr's Avatar
rtmorrisjr
rtmorrisjr is offline
well yesterday i got to replace a break line. was a 3/16 line that came from a coupler and went to what i believe is the abs unit (not sure tho) Also, it had 2 different size threads on it. one side was for the 3/16 line and the other for a 1/4 inch line. thought that was wierd. had to get the 3/16 inch line and then an adapter to make the other threads work. not hard just glad i brought the line and the nuts to napa w/ me.
  #103
Old 08-13-2007, 12:06 PM
RamManRiley's Avatar
RamManRiley
RamManRiley is offline
she pulled out a jeep liberty last night. funny thing is i didnt even feel it the thing just grabed it and yanked it out. gotta love the 5.9.
  #104
Old 08-13-2007, 07:59 PM
Sinister's Avatar
Sinister
Sinister is offline
does anyone know of an easier way to change the Damned Headlight Assembly?
it took me about 1 min to get the old one out.. but to get the new one in I needed to pull the headlight out of the bracket, adjust my pushbar to give space, slip the bracket in at such wierd angles just to get it in.. then stuff the headlight back in making sure to hit the adjustment pockets. then replace those damned clips. before bolting everything back into place.
but finally got the **** done.. pics i'll get once it gets dark again.. they look brighter even though they're still the same HIDS, and just new OEM assemblies again. .at least they're not covered in that brownish tint lights tend to get.
speaking of which, whats the best way to prevent that tint from returning?
  #105
Old 08-13-2007, 09:03 PM
ryans590's Avatar
ryans590
ryans590 is offline
Sinister youve got hid's in there?? whatcha think of them? where did u get them? do they make that much diffrence?
as for it yellowing i dont think there is any way to prevent it but u can use a fine grit sand paper and wet sand it out
  #106
Old 08-13-2007, 10:41 PM
Fox Fader's Avatar
Fox Fader
Fox Fader is offline
For the first time since I owned it I washed it, but I don't know how it looks cause it got dark as I was drying it and shining the tires...[&:]
  #107
Old 08-13-2007, 10:53 PM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
ORIGINAL: ryans590
I would like to know about the HID's as well. As for the yellowing on the outside, you can use random orbitalpolisher and a heavier grit paint polish once or twice a year and it shouldn't ever happen. I have this one and use it with the autopia setup: http://www.autopia-carcare.com/inf-pc7424.html
  #108
Old 08-13-2007, 11:06 PM
Sinister's Avatar
Sinister
Sinister is offline
ORIGINAL: aim4squirrels
ORIGINAL: ryans590
Thanks to both of ya.- i'll maybe polish them since both HLa's are brand new out of the box now..
HIDs.. well ****.. how to explain it.. you can see a roadsign reflecting back at least 500m down the road,., they lighten up everything, and are much better than some PIAAs or other cheap HighOutput light.
i've never though to actually take a picture of what it lights up, just of the lights themselves, once it finally gets dark enough outside tonight, i'll snap a couple pics., its 8:00 here and we still have probably another hour of daylight left
My HIDs are SilverEagle 6000k, I bought them at JBPower in Edmonton, who gets their supply from 'DIX'- apparently they were imported from china (the instructions chinese & english), but most other setups should be the same.. you have a choice between 2 and 4 ballast., which means you'd have low (2) or high/low (4). I picked the 2- and it was about 500+taxes and since i have two sets of foglights, i figured to set them up as 'highbeam' ; they light infront of me, and mainly where the hole is the HIDs dont cover in HI mode. the 4 ballast were about 100bucks more.
one warning though:: ANY HID installation MUST be done correctly so the bulbs are seated and will not move, they get hot enough to melt the assembly right through and possibly can cause fire.. warranty isnt covered if installed incorrectly.
- the light grommit will sit first then place that grey locking piece on, lock that into place, then stick bulb into grommit, and lock the bulb into place. doesnt move then.
- i'll update as soon as i get those pictures.
  #109
Old 08-13-2007, 11:16 PM
ryans590's Avatar
ryans590
ryans590 is offline
yah i sell/install the hid's at work but never herd what anyone thought of them after the ones we sell are "N Motion" and we sell piaa ones and kc ones too i suspose i just wanted to know if the 500 to 600 is worth it
  #110
Old 08-13-2007, 11:53 PM
Sinister's Avatar
Sinister
Sinister is offline
personally to me, yes.
funny.. only small cars and vans are really flashing me, when im on low.... trucks sitting higher aren't bothered... guess i'll have to reangle them.
backup
hmm- looks like my tag lights are out.
Quick Reply: What Did You Do To Your 2ND GEN RAM Today?
