Put some gas in it. It was between half and 1/4 tank and took 65L for 290KM, so that made my gas mileage out to be around 10.5MPG in town. Quite the improvement over the 7.3MPG I was getting before seafoam!
Also, wasn't driving it very easily with the snow and slush combinations we've been getting the past few weeks
I don't usually like additives. Most of them are snake oil but I'm a fan of sea foam. I truly believe it makes my truck run better
Went to the stealership they changed the oil,lubed up the suspension,installed a new oil and air filter, rotated the now worn out tires, and inspected the vehicle. o.o and the most important thing ,THEY CHANGED THE BLINKER FLUID!
I had my mother in law going on blinker fluid for 15 minutes last year, it was EPIC!
Dug out 5 rust spots above the right rear wheel well - 3 of which have been bondo'd, sanded, and painted. The other 2 I'll weld repair tomorrow morning.
Took the drivers door apart, removed the wiring, and removed the door from the truck. Cut out and removed several rusted/rotted areas from the bottom exterior, and the bottom of the door itself. Fab'd new sheet metal across the entire bottom, and some of the bottom exterior, welded into place, dressed the welds, skim coat of bondo, final sanding, and 2 coats of paint.
