Old Jan 19, 2015 | 09:19 AM
  #14781
renardk764's Avatar
renardk764
Installed a new Alpine CDE-143BT Head unit in the old girl this weekend. Used the Metra 70-1817 wiring adapter and the Metra 99-6501 Dash Kit. The Metra wiring adapter had the correct wiring color codes and it worked flawlessly. The dash kit has runners on the back which expand the units height to the 1.5 din creating a wiggle free solid install. Highly recommend!
On another note, discovered the importance of crimping the insulation on Butt Connectors via my neighbor who used to work for Amp. Seems the weak point in butt splice is where the wire is inserted into the metal sleeve. Crimping the insulator (after crimping the metal sleeve) end basically keeps the splice from moving and minimizes the force put on the splice when the wire is pulled. Years of using these things and never knew.
Old Jan 20, 2015 | 03:17 PM
  #14782
jsmith1969's Avatar
jsmith1969
Just changed out my dash with one from LMC. Looks soooo much better
Before-
After-
I have the new bezel but waiting to change out my radio first before I put it on, too scared a tab will break.
Old Jan 20, 2015 | 03:42 PM
  #14783
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
Nice looking dash!
Mine has a few cracks, but no holes, thankfully!
Old Jan 20, 2015 | 06:50 PM
  #14784
stewie01's Avatar
stewie01
Found premium for $2.00/g so put some in the tank....
Made the trip back to Fairfax from Indy, putting a lot of miles on the truck, it's been on trip for so long I lost count of the actual mileage, peaked at it the other day and it was around 190,000 I thinks....
Bout time for a new set of rubber but she's still moving right along, gimpy transmission and all
Old Jan 20, 2015 | 07:50 PM
  #14785
Blue Mopar01's Avatar
Blue Mopar01
Took the ole girl down a hill today and almost into a slough...interstate was pretty icy and going up a hill didn't help...
Old Jan 20, 2015 | 11:59 PM
  #14786
snowboundrmk's Avatar
snowboundrmk
Filled up with premium as well. Mine cost $2.30/gal though!
Old Jan 21, 2015 | 01:14 PM
  #14787
Wh1t3NuKle's Avatar
Wh1t3NuKle
Last night --
The respectable buyer of my former ORE axles arrived and picked them up. We drained the diff fluid and checked out the condition overall. Very pleased with them. Quite the pain in butt to load though. His front is pitched up on ramps to lower the tail gate....hahaha
Yeah, that is me pointing to his white beast. It's an 01 sport. We'll be seeing more of eachother.
Old Jan 21, 2015 | 01:46 PM
  #14788
And his truck is thinking: Some day, I will grow up to be just like THAT truck.
Old Jan 21, 2015 | 07:14 PM
  #14789
Spillage's Avatar
Spillage
New A/C compressor arrived... the dryer and seals didn't though.
Already have new belt, idler, and tensioner... hope the dryer makes here by the weekend.
Old Jan 21, 2015 | 10:25 PM
  #14790
1997JollyGreenGiant
Spillage,
I'll be replacing my A/C Compressor and Dryer this spring. Is there a good write-up that you can recommend I use for this procedure? Just wondering if you are using a write-up.
