Old Jan 12, 2016 | 10:22 PM
  #15371
1997DodgeRam's Avatar
1997DodgeRam
Replaced a bad thermostat. It was a fail safe so I was running cold not hot.
Backstory: It went out over the summer and I really didn't care since all I really noticed was truck warmed a little slow and ran just a little cold down the road when it was hot out. I was out of the country all this fall and got back around Christmas. At 30 degrees outside though the temp gage barely lifted off the peg at 130, the heat blew cold air, and I seemed to be on pace for a really bad tank of gas for MPGs. Nice to have my heat back and I'll report back if I see that roughly 1.7 MPGs come back after I get some miles on it.
Old Jan 13, 2016 | 10:45 AM
  #15372
bargeman's Avatar
bargeman
Originally Posted by 1997DodgeRam
$196 for safelight to come to me. All gaskets included. I found a promo code online and then got another 25 off since she struggled for a while on getting the wiper arms off until I helped. 3 years in my sight line I finally had enough. If I had to do a state inspection I am sure I would have had to do it sooner
25 bucks off Since you helped her with the wiper. thumbs up!
"If the women dont find you hansome, they should at least find you handy."
-Red Green-
Old Jan 13, 2016 | 09:21 PM
  #15373
frankie_b_jr's Avatar
frankie_b_jr
Wow, that's cheap. I think I paid over 200 for the last one I broke.... (don't ask) I have a nice crack in my current one, and have been reluctant to get it fixed. The crack isn't in my sightline, and after 5 years, I kinda got used to it....)
Temper temper. Lol. I know what you mean about getting used to it. The full width crack was there when I bought the truck ('07?). It has kind of... shall we say, spread over the years.
Thankfully I work for the county road department. We service all of the sheriff's vehicles, plus I'm on search and rescue. They tell me I should get it fixed, but don't press the issue
Old Jan 17, 2016 | 09:29 AM
  #15374
bargeman's Avatar
bargeman
fixed t case leak.
Old Jan 17, 2016 | 11:07 AM
  #15375
TSU_Delta_Chi's Avatar
TSU_Delta_Chi
I really wanted fog lights for my truck since it did not come with them from the factory. I went to the local pick and pull and found another 98 that had them and got the switch and plate to use in mine, spent some time looking up how to wire an aftermarket set in and then pulled my plate to swap the new one on and to move my airbag key to the new plate. Boy was I pleasantly surprised to see that my harness already had the wiring! I checked the fuse box and the slots for the fog light relays had the female clips installed in the slots and wiring going to them. I ran back to the junk yard, got the two fog light assemblies and the wiring for them that connects to the connector under the fan shroud as well as the two relays. After about an hour of trimming my factory bumper inserts to accept the lights and some sanding / clear coating of the lights, I have factory fogs with very little effort!
Not bad for $18!
Old Jan 17, 2016 | 11:33 AM
  #15376
Yeah, it seems that dodge only used one wiring harness for the trucks, so, all the connectors for various options are already there, whether you have them or not.
Old Jan 17, 2016 | 11:43 AM
  #15377
jsmith1969's Avatar
jsmith1969
Ran a can of Mopar combustion cleaner through intake, changed the plugs and oil.
Old Jan 17, 2016 | 07:27 PM
  #15378
snowboundrmk's Avatar
snowboundrmk
Cleaned it, replaced 3rd brake light bulbs and tinted the back window 50%.
Old Jan 17, 2016 | 07:36 PM
  #15379
Bwally1996's Avatar
Bwally1996
Warmed truck up, grabbed a bottle of water and started the decarbonization process, hoped that would help with my miss, strangely enough didn't see any smoke of any color come out of the engine during the 40ml bottle not too sure what that means
Thought I was running rich due to smelling a quite strong fuel smell but it turned out to be a fuel leak (yay) gotta pull the bed (or at least tilt the bed) to find out where I'm getting a leak from
Pulled the both door sensors in attempt to get my interior lights to cut off both tested good, pulled my headlight switch and lights went out fooled around and found out the two prong clip that goes into the switch was the issue and got to looking around and there's a copper contact that was bent and making contact all the time bent it back and voila lights work properly, got dash put back together
Depending on how cold it is tomorrow I may go under and re route my spark plug wires
Still gotta figure out why my washer fluid light is in even though the tank is full, gotta find my fuel leak and see if fixing that will fix my misfire at all, still gotta order a new upstream o2 sensor to get rid of check engine light
Old Jan 17, 2016 | 09:34 PM
  #15380
Try cleaning the sensor for the washer fluid.
Let us know how things turn out.
