Old 07-04-2024, 12:11 PM
Jimythefan's Avatar
Jimythefan
Jimythefan is offline
They were in there a little longer than I intended. Roughly 60k. I try to swap them out between 30 to 50 depending on how it's running, and it's been running great.
  #16962
Old 07-04-2024, 02:40 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,391 Likes on 3,131 Posts
That's actually really good..... I should prolly have a look at mine.... see how they are faring.... I don't think they have been in there even 10K yet though.
  #16963
Old 07-08-2024, 04:50 PM
2001_blue24v's Avatar
2001_blue24v
2001_blue24v is offline
Default Multifunction switch Issue
Hey all, I have an 01 2500 cummins and I’m having some issues with my dash/multifunction switch.
My high beams are stuck on, but the blue indicator light on the dash is not lit up. When I turn on my right blinker the blinker itself works but the dash indicator light does not come on. My wipers only work on LO mode, and the fluid pump doesn’t activate when I hit the button.
I believe it’s a switch problem but if anyone can help I’d appreciate it
  #16964
Old 07-08-2024, 06:45 PM
HeyYou is offline
If you have tilt wheel, pull the covers off the column, and check the connectors to the switch. If that doesn't solve it, start NEW thread in the Tech section.
  #16965
Old 08-25-2024, 08:29 AM
1997DodgeRam's Avatar
1997DodgeRam
1997DodgeRam is offline
Default Headlight replacement
Swapped out the headlight assemblies. The second set was yellowing and had multiple cracks so I swapped back to a new factory style set up and LED bulbs. HUGE improvement in visibility at night.
Now I need to trouble shoot my horn not working. Quickly ruled out fuse and relay by swapping around but found a big birds nest with hard boiled eggs and all when I went to look at the horns themselves and thinking they may be toast.
  #16966
Old 09-28-2024, 04:16 PM
Ugly1's Avatar
Ugly1
Ugly1 is offline
When I found this ASI pro performance branded blem on sale on ebay for $100 and still had the same warranty I finally caved and ordered one.
Only problem I could see was a few bent fins that went straightt in 30 seconds with the needle nose pliers. No need for the trans cooler in my case but who cares. 100 bucks, man
I doubt my efans will ever come on again.The thing is 2.75" thick at the fins.
Says made in China right on it. At least there no molded plastic pieces bonded to the metal anywhere.
I'm stoked!
The following 2 users liked this post by Ugly1:
frankie_b_jr (09-29-2024), Spillage (09-29-2024)
Quick Reply: What Did You Do To Your 2ND GEN RAM Today?
