Old Nov 30, 2009 | 10:26 PM
  #2151
004x41500's Avatar
004x41500
Originally Posted by SpcD1500
pulled off my blown out hub bearing, need to go get a new one tomorrow as well as a brake sheilds, waterpump gasket, and maybe a water pump
might as well do the water pump while youre in there.
Originally Posted by Oren09
265/75r16
Now to get some tire chains
haha nice. im hopefully ordering mine at the 1st of the year.
haha 900th post woohoo!
Old Nov 30, 2009 | 10:28 PM
  #2152
SpcD1500's Avatar
SpcD1500
exactly what i was thinking
Old Dec 1, 2009 | 01:33 AM
  #2153
jjtroutbum's Avatar
jjtroutbum
New 6x9s. Giant magnets and cage had to seal the old holes (duct tape) door panels barely fit back on. Sounds much better. Not looking forward to pulling the interior to hide a sub, rear speaker instal, and headliner repair.
Old Dec 1, 2009 | 01:37 AM
  #2154
Freakinkeith806's Avatar
Freakinkeith806
Today, I drove my RAM
Old Dec 1, 2009 | 08:36 AM
  #2155
rumble_truck's Avatar
rumble_truck
replaced driver wheel hub, new rotors, and new brakes. also installed a 102'' whip antenna with a new cb. also put up my new mossy oak headliner.
Old Dec 1, 2009 | 09:58 AM
  #2156
Sheriff420's Avatar
Sheriff420
265/75r16
what are they rubbing?
my 285 70 17s rubbed the back of the fender well if i hit a bump in a full lock turn.
i installed the HBS 2.5" coil spacer and now they don't.
i think the treadwright 285 70 17s are actually a little taller than a new tire in the same size because when i first got my truck it had bfg a/t in that size and they didn't rub at all. and if you think about it, how thick is the rubber under the new tread compared to when the tread was part of the original tire.
i know that style has a pretty good bite to it, its not a mud tire but it'll hold its own.
Old Dec 1, 2009 | 10:48 AM
  #2157
bigtman07's Avatar
bigtman07
Took it shopping and got Christmas stuff. Can't wait for the snow to get here to make some extra cash. lol
Old Dec 1, 2009 | 01:42 PM
  #2158
Sheriff420's Avatar
Sheriff420
i got everything in the engine put back together aside from the fan/shroud/belt and adding coolant. i think i'll be able to start it up tomorrow, yay.
i only ran into one issue while doing the plenum, i broke one of the little red locks on a fuel injector plug, so i'm going to have to zip tie it i guess.
and as far as cmckenna warning about the rusty front and rear bolts, i only had one give me a little bit of a fuss (luckily). i sprayed all of them with CRC Knock'er Loose a couple minutes before and the one that gave me a fuss wasn't really that bad.
when i got it backed off about 1/4" i felt it starting to bind up and i didn't want to snap it so i sprayed the knock'er loose on the threads and ran it back down, then up until it started to bind, then down... after about 5 times going up and down it came out as if it were a brand new bolt.
Old Dec 1, 2009 | 04:18 PM
  #2159
Freakinkeith806
Side note, I like your sig, kinda like mine! lol
Old Dec 1, 2009 | 04:29 PM
  #2160
Augiedoggy's Avatar
Augiedoggy
just did mine recently...not so bad..
