#302
#303
RE: What Did You Do To Your RAM Today?
Front brake pads... they were worn funny on the passenger side, you could tell one piston on the caliper was working harder than the other...I replaced that caliper last time I did the pads, but I just threw the 30$ pads on it. This time, they got the 50$ ones, because the last ones only lasted mearound 8K miles... then I just sprayed a bunch of throttle body cleaner into the throttle body and wiped off all the dust and crap on the butterflys.
#304
sticky'd to the top as requested...
keep in mind that the more sticky's you have at the top, the less you have to look at below. I can start a thread that has a link to all of these sticky's if you like and leave 1 dedicated thread at the top. just let me know.
#305
wooooohoooooooo we got it sticky'd thanx steve big thumbs up i think we all just got sick of searching for what page it was on because alot of us do something everyday to our trucks and like to either talk or read about it so this will be good i think.... anyoneelse?,,,,,j
#307
removed the radiator and fan shroud, power steering pump, and ac pump from motor also unbolted the flywheel and tranny bolts along with fuel line and other wiring for the engine removal, picked up the engine crane and hopefully be pulling it out tomorrow .
#308
#310
got the rad support out of the way, "moved" the ac condensor out of the way without disconnecting it along with the oil cooler, lined up the engine crane to pull out the motor, god dam canadian cold sucks though so i had to cut it short for today along with working night shift .
