Old Mar 27, 2010 | 11:29 PM
  #3231
MattV's Avatar
MattV
With the help of my new found friends here,....and of course my brother who is a great "wrencher" :
Ball Joints upper and lower
New Starter ( I thought I needed to clean my wire end and when we went to do it the starter fell apart in pieces)
Shocks
New hub on passengers side.
Fun fun!!
Old Mar 27, 2010 | 11:34 PM
  #3232
Maxx_Magnum's Avatar
Maxx_Magnum
Shocks
Fun fun!!
welcome to df! TONS of info around here, everything you'd wanna know about that truck
edit: just noticed, 04?? been here a while I guess eh?
Old Mar 28, 2010 | 12:14 AM
  #3233
004x41500's Avatar
004x41500
Originally Posted by Nando Vazquez
004X41500 can u post some pics. Today I cleaned out my trucks throttle body, took a look at the plenum leak and cleaned the Cold Air Intake Filter.
ill get em asap, ive taken em, just havent bluetoothed em from my phone to laptop. how does that airraid spacer do? any noticable difference?
also, im starting to look for a new valve body, anyone got any ideas?
or maybe its not the VB...idk im assumin it is, since my trans didnt start actin up till i changed the fluid and filter.
its throwin a 1757 code, governor pres. sensor low-malf. any ideas?
Old Mar 28, 2010 | 01:05 AM
  #3234
wermbang's Avatar
wermbang
Originally Posted by Maxx_Magnum
wermbang, love the leds! since you've done the led mod, can you tell me if say red leds would work in there? or is there a colour mask under there for the stock colour? I love red lights, every vehicle I've owned except this one had red ***** lights under the dash, I'm gonna do the truck too just haven't gotten around to it...
and about the trackbar, how do you know when they're toast? I just greased and checked mine yesterday. It seems good and tight, but my buddy with an 01 2500 replaced his a few months ago and he was also told that they go bad about once a year.... I haven't changed mine since I've had it, and god knows if it's EVER been changed
I would say no go on the red ones. The factory face as a green filter on it and white bulbs. Could always try it and see how it looks, my lights were under $10 for the 194s.
Old Mar 28, 2010 | 09:38 AM
  #3235
Sheriff420's Avatar
Sheriff420
This was a related video for the first and the third death wobble video. How is it related exactly?
http://www.youtube.com/watch?v=zKO-t...layer_embedded
Old Mar 28, 2010 | 05:25 PM
  #3236
004x41500's Avatar
004x41500
i just pulled out my friends aunts mini van that she got stuck in a ditch.
Old Mar 28, 2010 | 05:53 PM
  #3237
Dale Kramb's Avatar
Dale Kramb
Default i'm lost sorry
my van runs good cold ****'s good.hold it to the floor and will run thro the gear's fine. lot's of power. when warm's up won't **** if holding to floor if you let up the gas a hair will **** then.has loss of power when warm. take's for ever to get to 55mph . and if you hold it to the floor and it don't
shift it will act like it's going to to the riv chip, start's farting and bucking. have change the speed senor the tp senor and the map senor.. did a fuel presser test came up with 30 psi at idle . did the squeeze return line same presser. took it for a drive with presser gauge stell on and when i hold to floor the presser drop's to 10 psi be for shifting again have to let up on gas befor it will shift . guess i'm hopeing i don't need to do a fuel pump. thx's for reading this
Old Mar 28, 2010 | 06:33 PM
  #3238
green97's Avatar
green97
Any one have a back bumper for a 97?
Old Mar 28, 2010 | 08:07 PM
  #3239
004x41500's Avatar
004x41500
hard to understand, but unfortunately it sounds like your fuel pump is the culprit, as it should maintain a steady 30+psi throughout the entire rpm range.
its not hard to do, check the DIY section, and make sure you have less than an 1/8 of a tank of gas otherwise its a P.I.T.A to do.
though the almighty chrysler gods made the filter, pump, and sending unit all one piece, and it doesnt come cheap. ~$240.00USD
the reason it runs like crap when hot could be because when an electrical motor is cold it has less resistance to electricity, the warmer it get the more resistance it has, thus a weak pump will have trouble keeping up the fuel pressure causing your vehicle to surge/stumble and miss as well.
hope this helps some.
Old Mar 28, 2010 | 08:33 PM
  #3240
mnewbolds's Avatar
mnewbolds
I made a sacrifice to these "all mighty chrysler gods" today. $80 for a tank of 93 oct. Runs good but when will they smite me once more?
