Old Apr 6, 2010 | 05:06 PM
  #3311
004x41500's Avatar
004x41500
Originally Posted by Sam_Ram_WNC
BOUGHT IT!!!
It's my first Ram and full-sized truck!
1999 Dodge Ram 1500 SLT Laramie
welcome to DF,
you will also find that,
my dodge was also my first full size and first dodge, though my stepdad has had a few before i got mine.
anyways, i finally figured out why my cb wasnt working right, maybe if i wouldve done a continuity test sooner, i mightve been working faster. lol.
sure enough my center pin on my antt. stud was shorting out to my mount, causing an issue there, so i just made the hole a little bigger, and put the plastic washer back in properly, and bam, it solved my problems.
I found a diagram online that shows you what is supposed to have continuity and whats not, if anyone needs it just let me know, and ill send you the link, or ill just post the diagram
also someone was asking about pictures of my dash after i painted it, i got those as well as a pic of where i moved my cb too.
here you go.
looking to the right. (you can see where my power invertor is mounted, yes my cup holder still drops down)
looking to the left.(you can see where my train horn button and compressor switch are mounted as well.)
and as you would see it if you were looking straight ahead driving.(you can see the cb, invertor, and the train horn button, and compressor switch)
Old Apr 6, 2010 | 06:23 PM
  #3312
mnewbolds's Avatar
mnewbolds
Found a new leak, AWESOME! Rear window seal is dumping water. Everything in the behind the seat storage is ruined including my new Ipod and a couple of VERY expensive power inverters... Other than that I just drove to Pizza Hut. Maybe there will be some sun tomorrow.
Old Apr 6, 2010 | 06:33 PM
  #3313
004x41500's Avatar
004x41500
no bueno...id be really pissed right about now. lol. well hoepfully when everything dries out it should be good, the invertors should be ok if they werent powered on or plugged in when the water was leaking in.
Old Apr 7, 2010 | 12:13 AM
  #3314
95MaroonMonster's Avatar
95MaroonMonster
drove to work....pulled a 5 ton capacity AG spreader wagon back to the CO-OP (rented to spread 0-0-60 red potash)
then into South Bend to meet the parents at the Volcano for lunch and back to work
Old Apr 7, 2010 | 12:51 AM
  #3315
yakkier's Avatar
yakkier
Replaced driverside hub and u joint, will be posting pic's when im finished.
Old Apr 7, 2010 | 09:15 AM
  #3316
1998ram5.9's Avatar
1998ram5.9
I filled my skool parkin loy with smokey burnout and just drove to work
Old Apr 7, 2010 | 09:29 AM
  #3317
Sheriff420's Avatar
Sheriff420
Are you sure it isn't your third brake light gasket? I thought my rear window was leaking a while back so I put a bead of black window sealant around the entire edge where the rubber meets the paint, but it persisted to leak. Then I found out that the third brake light was the source through a little research on here.
Old Apr 7, 2010 | 10:44 AM
  #3318
yakkier's Avatar
yakkier
pull drivers side hub back off again, installed new ladder rack..... will post pics when i get the hub back togeather AGAIN
Old Apr 7, 2010 | 01:07 PM
  #3319
BlueBeast2's Avatar
BlueBeast2
Got the tranny flushed finally, He said it was DIRTY. Guess when it gets hot it really does turn ****ty. He mentioned my belt was squeaking like hell. Wasn't doing that before. I don't really remember it doing it last night when I drove it over there either (I was kinda buzzed though so it might have been). It sounds like its coming from around the tensioner so it might be that. The idle was a little weird when I first fired it up too and the wideband was showing lean. I'll have to keep an eye on that.
Ordered my viair 480 last night. All air horn parts are on their way
Old Apr 7, 2010 | 01:13 PM
  #3320
mnewbolds's Avatar
mnewbolds
I thought about that too, I will have to wait for a friend or neighbor to help me remove the topper so I can get in there. I will be sealing it all up. Oh, and the inverters were running my compressor and I noticed it when it smelled like burning plastic in the cab. So yeah the inverters are fried. The Ipod is still drying. Now I am having problems with the wipers. They will go 3-4 times before stopping on intermittent. Will it ever end?
