Old Feb 23, 2009 | 06:14 PM
  #571
PurplDodge's Avatar
PurplDodge
Changed the Power Steering fluid. Drives much better and the steering is more responsive. Also cleaned the inside.
Old Feb 23, 2009 | 08:06 PM
  #572
dodgeram07's Avatar
dodgeram07
i got new tires about a month ago, so check psi it was 35 (b.s) it should have 44 psi so the guy who put on the tire didn't feel like filling them up all the way.
started pulling dirt and grass out of the rear bumper( got stuck over the weekend)
Old Feb 23, 2009 | 09:29 PM
  #573
MAJohns's Avatar
MAJohns
got superchips 3815 ran on 87 tune and gonna fill up tomorrow and do 91 tune and will let yall know what the milage did on 87!
Old Feb 23, 2009 | 09:31 PM
  #574
xskylinedx's Avatar
xskylinedx
Installed a CompCams double roller timing chain and a GMB hi-flow water pump.
Old Feb 23, 2009 | 09:33 PM
  #575
MAJohns's Avatar
MAJohns
was that a bad job or just time consuming?
Old Feb 23, 2009 | 09:43 PM
  #576
xskylinedx's Avatar
xskylinedx
it was my first time ever doing it so it was very time consuming. I tend to double and triple
check when I do things. I tip though: buy your gasket set locally. I picked at set up from
summit because thats where i ordered everything else and I ended up with the wrong stuff
in the middle of my job.
Old Feb 23, 2009 | 09:49 PM
  #577
MAJohns's Avatar
MAJohns
i hate when that **** happens i get so pissed!!! thanks for the tip!
Old Feb 27, 2009 | 10:13 PM
  #578
jpbrog's Avatar
jpbrog
95 cut the cat off made y pipe and cut hole 4 the o2 sensor
Old Feb 27, 2009 | 10:37 PM
  #579
dodge15004x45.9's Avatar
dodge15004x45.9
got my tow mirror hit inn traffic its broken.
Old Feb 28, 2009 | 08:33 PM
  #580
Forkliftech74's Avatar
Forkliftech74
Thumbs down Speedo
I finally figured out my Speedo Issues on my '98 2500 4x4. Turns out ,in 1998 the retards at dodge decided to put the speed sensor on the fricken rear axle!!!! This lead to an Intermittant speedo problem,. So anyways I traced the wires from the frame on the left side to the top of the rear axle. I replaced the wires with new ones, soldered and shrunk wrapped all connections, and replaced the speed pickup just for good measure. Works good now. My 94 is a much nicer design. I guess if you never get yer truck dirty or go in the mud you'll never have a problem .
Fork
