Old Jan 15, 2012 | 12:04 AM
  #6261
gdstock's Avatar
gdstock
I started to put brake shoes on and noticed springs on one side were distorted and parking strut spring broken into pieces. One adjusting screw frozen, so had to order parts. Installed new wheel cylinders (GM 1 ton). Painted drums.
Also pulled differential cover (it was leaking) to check it and change gear oil. Everything looked good, cleaned and painted cover before replacing.
Did a little more sanding on body.
Old Jan 15, 2012 | 01:00 AM
  #6262
autolockguy13's Avatar
autolockguy13
forgot to mention i put in the 3500 wheel cyls instead of the 1500's. the truck brakes so much better overall. havent had to pull anything yet so we will see how that feels
Old Jan 15, 2012 | 11:58 AM
  #6263
redneckrocket38's Avatar
redneckrocket38
Sold it!
Old Jan 15, 2012 | 02:15 PM
  #6264
lastrights's Avatar
lastrights
Bummer
Old Jan 15, 2012 | 04:56 PM
  #6265
Oren09's Avatar
Oren09
Did a compression test.
About 60-85PSI across all cylinders.
Repeated as a wet test with a bit of oil in the cylinders. 150PSI.
I have worn or stuck rings
194,000 miles though, so not too surprising.
Old Jan 15, 2012 | 06:21 PM
  #6266
Yeah, that's most certainly rebuild territory there..... the fact that they come up so dramatically speaks to the bores still being in pretty good shape.
Old Jan 15, 2012 | 08:30 PM
  #6267
WoodRam's Avatar
WoodRam
Default tune up and clean up
I took off the throttle body and cleaned it. While the throttle body was off I took a look at the plenum plate. It looked fairly good. It looked clean.
The shop had changed the spark plugs earlier, so today I changed the wires, rotator cap, and button.
In the last month I have changed the serpentine belt, replace the u joint on one of the front wheels. Pooped out before I changed the other side. I also changed the water hoses and flushed the radiator.
Next up is oil change, and doing something about the electric lock switch on my door not working. My arm just can't stretch to reach the other door.
doing some thing about the exhaust. I am hoping to change over to something that will improve the mpg a bit. Perhaps a little later I will add a CAI.
Old Jan 15, 2012 | 08:52 PM
  #6268
stewie01's Avatar
stewie01
Today I looked at it and said "Nah, I don't feel like going anywhere". I'm practically gonna live on the road this week. Got 730 miles of driving to do in 4 days then up to Virginia, another 500+ ish
Old Jan 15, 2012 | 09:01 PM
  #6269
gdstock's Avatar
gdstock
Started primer today.
Old Jan 15, 2012 | 09:03 PM
  #6270
Gonna do mine next.... Right?
