Old Nov 4, 2012 | 07:49 PM
  #8641
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by jkeaton
Then, after obtaining a more suitable item to stand on so I can reach the $#@ thing, I will attempt to locate the actual IAC. And no......no pictures.
I use a Tire Step. Works great, and can't slide out from under me. It makes lots of those under the hood jobs a lot easier. Heck, I'm heading back out into the garage in a few minutes to put mine back to work.
Old Nov 4, 2012 | 08:00 PM
  #8642
Wombat Ranger's Avatar
Wombat Ranger
^^^I use my bumper. Also, if you just pull the whole throttle body off it's much easier to tinker on.
Old Nov 4, 2012 | 08:04 PM
  #8643
crazzywolfie's Avatar
crazzywolfie
i just pull up behind my other truck and drop the tailgate. lucky for me tho i could sit under the hood of my trucks and fix stuff.
and just for your info the IAC is on the back of the throttle body.
Old Nov 4, 2012 | 08:27 PM
  #8644
redneck_ram's Avatar
redneck_ram
did sone end of the season yard work
it was about a yard and a half of loam.... used my plow to spread it out. trying to level out and fill in a small ditch in my yard. still need about 3-4 yards of loam. love making my truck work.
after i swept out the remaining dirt i put my ballast retainer in. couple more weeks and the ballast will be in for good until spring.
Old Nov 4, 2012 | 10:08 PM
  #8645
Yeah, but then I will see all that oil pooled in the intake....I'm not ready to tackle that job yet....I just got the truck a month ago!
Old Nov 4, 2012 | 10:09 PM
  #8646
You call that work? Not even on the bump stop...you coulda put another half a yard in there!!!
Old Nov 4, 2012 | 10:49 PM
  #8647
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
I do that too. But I have a brush guard to it's kind of a pain.
I've done this on mine too.
Old Nov 4, 2012 | 11:14 PM
  #8648
redneck_ram
if it was a stock rear suspension it would have been on the stops and then some. i have a 2" HD add a leaf in there. truck dont.move at all. thays the most ive ever had in the bed!
Old Nov 4, 2012 | 11:24 PM
  #8649
I do notice the shock completely compressed. lol
Old Nov 4, 2012 | 11:34 PM
  #8650
Spillage's Avatar
Spillage
Topped off the power steering fluid, as it was at the low mark (first time this was ever needed since new).
Did some more sleuthing on the coolant consumption issue... I'm confidant (thankful) that it isn't the heater core... I noted a few drips of water from the front lip of the oil pan, dripping onto the cross member... the inside of the water pump pulley and the bottom of the water pump bearing housing did not appear wet... more investigation needed.
Since the heater core is not the culprit, that means the water on the passenger floor has to be coming from the rear cab seam or the window, despite not being confirmed by a hose down last week... the floor has dried since we've had several rain free days, so this also points to a cab leak.
So I took a small tube of "flowing" silicone window sealant and ran around the cab seams, the rear window, and 3rd brake light, just for good measure.
The next heavy rain will be the test.
