The Official 2nd Gen RAM Forum OT thread
If you can get the brand and model of your engine, I'd advise that you do some reading on how the carb operates under normal circumstances.
Need to set the float level in the carb, not hard to do turn it upside down make sure the bottom of the float is level, if not adjust the little tab on the float by the main needle. There is also the possibility that the float has a hole in it if its copper or white, or a saturated black float.
on
It's a Kohler 14Hp.
Seems like a damn good little motor, just gotta get the carb issue figured out...
Luckily I was able to get everything mowed today
![Smile](https://dodgeforum.com/forum/images/smilies/smile.gif)
on
Might have to take you up on that.
Kohler motors have been around forever and are good motors. Give me the ser number and the model number (off the little metal tab on the motor) so I can check out what you are playing with.
