The Official 2nd Gen RAM Forum OT thread
Old Sep 1, 2013 | 10:28 PM
  #12691
merc225hp's Avatar
merc225hp
It should be on the air horn stamped into it. I will see what I can find for you.
Edit:Yep you can get them seperate about $9, you have to take the whole carb apart to install it, so better get a kit with all the gaskets. There are a couple of opts so I will not post part numbers.
Old Sep 1, 2013 | 10:34 PM
  #12692
crazzywolfie's Avatar
crazzywolfie
ya. if the carb has not been touched in years the old gaskets may be a real pain to remove and will most likely tear. i know that i had the issue with the holley carb i bought.
Old Sep 1, 2013 | 10:39 PM
  #12693
merc225hp's Avatar
merc225hp
^^^ This is for both of you I thought you might find it informative, sorry if you already have it bookmarked.
http://www.rockcharger.com/tech/vaan...quad_guide.txt
Old Sep 1, 2013 | 10:41 PM
  #12694
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Hmm...tearing the whole carb apart is not something I wanted to do.
I guess it will have to go on the list. Do you guys think that might be what's wrong with it though?
Old Sep 1, 2013 | 10:45 PM
  #12695
merc225hp's Avatar
merc225hp
A bog can be too lean or too fat, off idle circuit could be plugged. Need to hook up a vac gauge to see what's going on. You have to learn sometime, find another carb to rebuild this way no biggy if you have a problem along the way. Does the vac advance work? test it.
  #12696
crazzywolfie
i am mainly a holley guy but i saved the document to my computer just in case. thanks
Old Sep 1, 2013 | 10:57 PM
  #12697
crazzywolfie
does it look like this?
Old Sep 1, 2013 | 10:59 PM
  #12698
Gary-L's Avatar
Gary-L
Veteran: Navy
Old Sep 1, 2013 | 11:03 PM
  #12699
dodge dude94
Well, the idle air mixture screws don't do anything. I've chased leaks, to no avail. Finding another carb locally is like a needle in a haystack. Hardly anyone around here runs stock carbs anyhow and the factory units are always long gone. I don't know if the advance works or not, I plug it and it doesn't run any different.
Yep, rebuilt Carter TQ.
Old Sep 1, 2013 | 11:04 PM
  #12700
stewie01's Avatar
stewie01
George W. should be in the pic too....
