The Official 2nd Gen RAM Forum OT thread
Old Sep 1, 2013 | 11:16 PM
  #12701
merc225hp's Avatar
merc225hp
Well, the idle air mixture screws don't do anything. I've chased leaks, to no avail. Finding another carb locally is like a needle in a haystack. Hardly anyone around here runs stock carbs anyhow and the factory units are always long gone. I don't know if the advance works or not, I plug it and it doesn't run any different.
This could be all about the advance not working, as more fuel is add the spark curve must match it. OK guys its been a long time since I touched a old Mopar this is vac advance right? I would first find out if the vac port on the carb does indeed supply vac upon acceleration, but none at idle. If this does not work find a port on the carb that does. Next for as cheap as they are just replace the vac pod on/in the dizzy should be two screws and a clip, also make sure the timing advance plate moves freely in the dizzy. To test the vac pod press it all the way in and hold your thumb over the hose port, it should stay put until you remove your thumb from the port.
Old Sep 1, 2013 | 11:21 PM
  #12702
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
IIRC is does supply vacuum the way you described. I didn't think about playing with the advance plate. I will do that when I get a chance to, gonna be gone tomorrow.
I bookmarked your post btw, Thanks.
Old Sep 2, 2013 | 10:40 AM
  #12703
dodge dude94
For me it would be the knockers as I don't like most of the donuts in that tray.
Old Sep 2, 2013 | 11:04 AM
  #12704
stewie01's Avatar
stewie01
Knockers do look nice. And donuts are overrated.
Old Sep 2, 2013 | 11:16 AM
  #12705
aofarrell2's Avatar
aofarrell2
Originally Posted by snowboundrmk
So that is just the technical name for the stock Dana 60 front axle on 2nd gen rams?
Exactly.
There was rumour of a 88 on 3500 CAB CHASSIS, but I have not confirmed that it actually went into production. If you needed such a tuff axle you could put a sterling 10.5" FS up front.
Personally I only need a 66 up front, I'll beef up the front suspension parts to enable proper distribution of weight so it doesn't stress anything. I chose the sterling 10.25 as I can uprate the truck more with that on it than a 80.
If i do the axle swap, I'll get a custom made door decal that reads: "Ram W3500HD Custom" Seriously.
Old Sep 2, 2013 | 11:17 AM
  #12706
aofarrell2's Avatar
aofarrell2
^^^ +1 No such thing as a 66 or a 40. Dana diff's
28,30,35,44,50,60,61,70,80 suffix could be F, U
Interesting. All dodge dealers use the reference I was talking about. I'll have to chew 'em up.
Old Sep 2, 2013 | 12:02 PM
  #12707
QuadCabLuv's Avatar
QuadCabLuv
mmmmmmmmmmmm boobies
Old Sep 2, 2013 | 12:03 PM
  #12708
merc225hp's Avatar
merc225hp
Nowhere in the parts book or on the dana site is a 66 referred to. Your dodge guys are smoking crack it was never made. Don't post BS, google dana 66 and see what info you find about it.
Old Sep 2, 2013 | 12:11 PM
  #12709
QuadCabLuv's Avatar
QuadCabLuv
I WANT THIS, SCRATCH THAT I NEED THIS.
http://www.satterfieldmotorco.com/we...ansas/1360712/
Old Sep 2, 2013 | 12:15 PM
  #12710
Gary-L's Avatar
Gary-L
Veteran: Navy
Bloody hell. That thing has been barely used with only 122K on the clock.
