The Official 2nd Gen RAM Forum OT thread
Some 5.2 specs. Not my work and I can't credit it because I don't remember where I got it from.
Throttle body: dual 50mm bores. Chrysler patented 'Progressive Bore' necks this down to 48 mm at throttle shaft )
Theoretical Throttle Body Flow capacity: 440 cfm.....due to restrictive air intake system or 'Progressive Bore choke point, use about 400 cfm for best match
Intake Manifold runner length along centerline: 15 inches. Top of runner 17.75 inches and bottom length 12.75 inches.
Intake Manifold runner 'equivalent' diameter 1.59 inches
Intake manifold design type: single plenum with 90% divider (almost a dual plane....intake manifold seems to be quite restrictive at high cfm flows**
.....gross intake valve lift 0.432
gross exhaust valve lift 0.432
Notes:Factory Dakota RT exhaust seems to be about 550 cfm, resulting in +15 hp increase.
{all of the above data can be used to show that the new cam at the factory is installed 3 degrees retarded, but timing chain wear might gradually advance this. The camshaft specs may have changed a few times since 1992 as the factory tweaked them a bit, and eliminated EGR in 1997**
I won't turbo it, lol.
I would like to get one of those 2 intake systems you guys talk about on here. I just don't see myself spending that much for that and paying a fortune to put it on if it just don't bolt right up.
If I didn't have to get someone to put all this stuff on, it would be different. People charge a fortune around here.
It'd be cool but if he wanted to use anything 93 octane or lower he'd probably have to lower compression through various means (low comp pistons, headgasket shims, etc.)
VDub (Gary-L) IDK what to think about your new sig.
good to know guys. just put it out there incase someone overlooked it.
![Icon No](https://dodgeforum.com/forum/images/smilies/icon_no.gif)
There out there used, just have to hunt on the web for them.
