The Official 2nd Gen RAM Forum OT thread
Old Nov 8, 2013 | 04:23 PM
  #14141
merc225hp's Avatar
merc225hp
^^^ So what you flipped your mattress over?
Old Nov 8, 2013 | 04:28 PM
  #14142
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Sure, we'll go with that.
Old Nov 8, 2013 | 04:53 PM
  #14143
BBartow's Avatar
BBartow
Old Nov 8, 2013 | 06:20 PM
  #14144
stewie01's Avatar
stewie01
^ Totally awesome!
Old Nov 8, 2013 | 07:20 PM
  #14145
aofarrell2's Avatar
aofarrell2
Speaking of paint...
I noticed the paint on the hood is peeling now.
That does it.
Cab was bad enough... Now the hood too?
I pumped 15-16 gallons out of the rams tank into the 03 caravans tank. Whew. 20GPH is slow. Lol.
Old Nov 8, 2013 | 08:28 PM
  #14146
Gary-L's Avatar
Gary-L
Veteran: Navy
Originally Posted by stewie01
^ Totally awesome!
X2. Hell YEAH!
Old Nov 8, 2013 | 09:34 PM
  #14147
Jigabop's Avatar
Jigabop
Originally Posted by dodge_dude94
Apples to oranges again I see.
If diesels are the way to go, why don't manufactures offer only diesels and tell the EPA to shove it?
because americans are stupid and think gasoline is cleaner and better.
they are also cheaper because they are throw away motors that are not built nearly as strong which makes them not hold any value vs a diesel and wear out significantly faster than a diesel.
and it takes making them a hybrid to make them even remotely as efficient as a diesel? pathetic.
I have yet to see gasoline make a 3500 long bed pickup pull off 20+mph AVERAGE
I see stock diesels do it all the time.
oh yeah merc: I'd love to see you try to build a 318 or 360 to 500+ hp on pump gas without changing anything inside the block...pushrods, valve springs are fair game, forced induction and injectors/ignition/whatever is fair game as well...
but must use stock cam, stock pistons, stock crank, stock connecting rods, stock heads.
love to see you pull it off and have the same reliability
the complete bottom end of my engine is stock. the head is stock, the rockers and valves are stock, the cam is stock, lifters are stock. transmission is stock other than added cooling and a dual disc clutch.
drivelines and xfer case is stock, rear ends are stock. oh and it runs on #2 diesel just like it did when it was bone stock
Old Nov 8, 2013 | 10:33 PM
  #14148
Ham Bone's Avatar
Ham Bone
Hey Jig you got them Neon springs dont forget about those
Old Nov 9, 2013 | 11:58 AM
  #14149
Gasoline doesn't put out near the volume of soot that a diesel does. Emissions controls on gas engines don't compromise power on near the scale that diesels have to deal with.
Gasoline is upwards of 70 cents a gallon cheaper than diesel here. I can average 13-14 MPG in my daily driving.
Maintenance on my gas engine is a lot cheaper. I can get my oil changed by someone else, while I sit in a comfy chair, and read a book, for 22 bucks. You can't even buy your oil for that.
That diesel engine is still bolted into the same truck as my gas engine, and all those parts wear at the same rate. (actually, probably faster for front end parts, due to the additional weight of the diesel.) I will grant that your engine will probably still be in good shape, long after the rest of the truck has become useless.
Diesels have their advantages, but, they have their drawbacks as well. You are happy with your oil burner. Good for you. I am happy with my gasser. Good for me.
Would I like to have a diesel? Yep. But, given the cost difference between the gas, and diesel trucks..... I am going to stick with gas. (unless a REALLY good deal comes down the pike.)
Old Nov 9, 2013 | 12:32 PM
  #14150
Gary-L's Avatar
Gary-L
Veteran: Navy
Volkswagen and Nissan both have diesel engine systems that burn cleaner than any gas powered engine.
Fuel may be higher for a diesel, but the mileage and performance actually reduces that cost. The lifetime maintenance costs would have to be reviewed before claiming that the gasser is cheaper to own.
