The Official 2nd Gen RAM Forum OT thread
Old Mar 22, 2013 | 11:47 AM
  #7881
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Originally Posted by gdstock
A bigger problem is folks posting a 1" picture here. I cannot see that stuff that small!
A WHOLE ten minutes? We would have really liked pictures of that!
Technically, it was only supposed to take 5 minutes, but i got sidetracked.
Old Mar 22, 2013 | 12:14 PM
  #7882
stewie01's Avatar
stewie01
Good tune:
Interesting video
Old Mar 22, 2013 | 01:50 PM
  #7883
stewie01's Avatar
stewie01
F@CK!
Old Mar 22, 2013 | 01:59 PM
  #7884
merc225hp's Avatar
merc225hp
^^^ Froze and split or? Well pump?
Old Mar 22, 2013 | 02:01 PM
  #7885
stewie01's Avatar
stewie01
That is a good question. It just happened a few minutes ago.
It's for the boiler heater.
Found a replacement for $130.35 locally, cheaper online, but not by much.
Old Mar 22, 2013 | 02:30 PM
  #7886
merc225hp's Avatar
merc225hp
Cerc pump for radiant heat. Could be a steam fracture if the pump failed.
Old Mar 22, 2013 | 02:36 PM
  #7887
aofarrell2's Avatar
aofarrell2
teh ****?
LOL. TFT Matrix is a special type of LCD screen. Much better contrast, sharper colors, and better 3D. IBM is the almost exclusive user of them.
@ beginningjockey; So what are racing wires and when did you do the kegger mod (modified plenum)? Pix of this intake mod, what difference did it make? Was it worth it? What all was done for this mod?
There are three main types of spark plug wires: Street (Red), Strip (Yellow), and Racing (Blue). The color codes are from the brand I use (Belden, which is carried at most NAPA stores). They are all listed as 8MM wires, but there is a difference. Street uses a metallic conductor. I do not know what conductor strip uses, because I have never needed to use spark plug wires in a strip application. The Racing grade (Blue) is a 8MM non-metallic conductor, with extra shielding. It has a larger core than most standard wires, thus enabling it to transmit higher voltage. I chose this because it is a significant improvement over most street styles with the different core, better insulation, and higher capacity. Between the racing and premium street styles, I have noticed a big difference in spark strength. It's ideal for running a stronger coil too. Here's the set I got: http://www.napaonline.com/Catalog/Ca...614_0267518052
I did the kegger mod when I replaced the plenum plate and gasket. That was before the transmission went out.
I'm trying to find the picture LOL. I'm certain I posted a pic somewhere on DF, but can't seem to find it.
What difference did it make? For one it got my power band in a acceptible location (2500-3500RPM, instead of over 4000RPM). I also replaced my heads while I was at this, so the heads might have made a difference. And I also put on true dual exhaust. So how much effect the plenum mod exactly had, I don't know. It was enough reduction in restriction in the intake that it cause the MAP sensor vacuum reading to cause the computer to think it is under load (I verified this with a OTC tool). So be careful - you'll need a tune to compensate for this if it happens. This is why my truck is running rich too. All in all, I would do the plenum mod even if it didn't seem to make a difference. I am also running a 180* tstat without a tune and having no problems with it.
So bottom line here, whatever the combination of the above, it had a amazing effect on the performance. Before it was always slow to accelerate - after, it would put-you-back in the seat with ease. But that was probably why the transmission went out shortly thereafter.
Helpful explanation?
Old Mar 22, 2013 | 02:38 PM
  #7888
stewie01's Avatar
stewie01
@merc: What happened is I was in the kitchen running water and water pressure was terrible, almost none.
Went outside and heard water, there's a screw cape a little further up the piping that had either been blown out or came loose, and water was gushing out of it, so I screwed it back in, wasn't sure what had happened, so I turned the boiler on, it ran fine (and still does) and then I heard water again, and the case was cracked on the Circulator.
Old Mar 22, 2013 | 06:44 PM
  #7889
woods4life's Avatar
woods4life
Yeah, thats a nasty lookin crack! Might want to get that replaced hahaha
Or......
Attached Thumbnails The Official 2nd Gen RAM Forum OT thread-duct20tape-2015176538.jpg
Old Mar 22, 2013 | 06:46 PM
  #7890
dhvaughan's Avatar
dhvaughan
^ now that's funny.
