Miles per gallon- What are you getting?
Old May 20, 2005 | 05:46 PM
  #31
securtis12's Avatar
securtis12
Default RE: Miles per gallon- What are you getting?
Just got my 99 1500 quad cab 4x4 5.2 and got 15.5 to 16 on the hwy (bought it in maine and drove to south carolina next day). It does have a k+N filter and 265 AT tires. If you figure in the actual miles traveled (245 stock vs 265) was alot closer to 17. Not to bad but am considering a TB spacer and maybe a cold air intake plus synthetic in diferentials.
Old May 20, 2005 | 11:35 PM
  #32
richardmoore's Avatar
richardmoore
I've got a 98 1500 with 6 inchse of lift and 35's. I get 10.1 mpg in the city and 12 on the hwy, on a good day!
Old May 24, 2005 | 01:08 AM
  #33
95broncoxlt's Avatar
95broncoxlt
You guys get better mpg than my Bronco, I average about 10 at the best with a 302.
Old May 24, 2005 | 02:57 AM
  #34
dodg_24's Avatar
dodg_24
I get 10-12mpg. But I have 33x12.5inch tires and small lift.
Old May 24, 2005 | 07:09 AM
  #35
zeekxxx's Avatar
zeekxxx
-----the only accurate way to check is fill up, reset the trip meter and the next time you fill up divide the miles by the gallons.
Here is what I do when I want to figure out what I get on the highway. I tank up till it wont take no more. Then I drive 25 miles in 1 direction. I drive at normal speeds - or normal to me - I hit the turn around and drive 25 miles back. I go right to the gas station and fill up at the same pump and try my best to get the same amount of gas in it. Then I do the math. I find this useful when I change tire sizes and see if its really worth regearing the rear end. If I only lose a small amount overall I dont bother. Most likely I dont need to drive 50 miles over all but its a nice number...
Good luck
Old May 25, 2005 | 02:53 AM
  #36
Cici22499's Avatar
Cici22499
Ok so please excuse my ignorance as i am brand spanking new at this.. is there anyway to increase your mpg without making your truck sound like a garbage disposal by using the bigger exhaust.. not to offend, i just don't prefer it with a sleeping baby in tote=)
Old May 25, 2005 | 11:27 AM
  #37
securtis12's Avatar
securtis12
ORIGINAL: zeekxxx
Good luck
The only problem with that is unless you recalculate your spedometer you are not getting an accurate reading
Old May 27, 2005 | 01:56 AM
  #38
kossuth's Avatar
kossuth
ORIGINAL: Cici22499
Bah, my baby loves the sound of the motor humming away. Not sure why but it is a for sure way to get her to sleep. Doesn't want to go to bed, take her for a ride in the truck and mission accomplished LOL.
Old May 27, 2005 | 03:16 PM
  #39
zeekxxx's Avatar
zeekxxx
---- The only problem with that is unless you recalculate your spedometer you are not getting an accurate reading
Yup I left out the garmin gps unit on my dash I use to get the milage..
Good eye though .....
Old May 27, 2005 | 03:19 PM
  #40
zeekxxx's Avatar
zeekxxx
ORIGINAL: Cici22499
Yup flowmaster 50 series
K&N cold intake
Fastman Throttle body
tune up with cap plugs and rotor and wires.
buy the correct tires for your truck.
keep them aired up to correct psi
shorty headers
maybe mds ignition.
high flow cat
that should keep you broke for awhile
