this dodge motor a good deal ?
Old Oct 25, 2010 | 12:20 AM
matty675's Avatar
matty675
what should i be concerned with as far as workmanship goes?
Old Oct 25, 2010 | 12:25 AM
matty675's Avatar
matty675
does it need injectors to run nicely, could it run good with the stock tb?
Old Oct 25, 2010 | 12:36 AM
matty675's Avatar
matty675
will the flat top pistons be a problem?
Old Oct 26, 2010 | 12:09 PM
Watch your compression ratio. Don't wanna get too high, else you will have to run race gas. (read: expensive....)
A good set of slightly larger, flow matched injectors might not be a bad plan.......
The shortblocks are pretty stout to begin with, its the heads/intake manifolds that were the weak points. If it was done by a professional builder, should be good, if he did it himself, might be a different story...... but, if he knows his chit, should be golden.
