Here's my beater!
Old 11-14-2010 | 01:44 AM
SyKo450's Avatar
SyKo450
Originally Posted by lastrights
i had those before my projection , i liked em alot , def better than stock ! i put in blue corner bulbs to make em stand out more than just haveing the orange bulbs in
Need to check if that's legal in Cali
Originally Posted by VWandDodge
That's a beater truck? Dayum!
Yeap
Originally Posted by 95RAM360
damn, those tires look great on the truck, good choice.
post pics of work in progress
Thanks, will do, new brakes, rotors, and bearings go in tomorrow
  #22
Old 11-14-2010 | 09:30 AM
lastrights's Avatar
lastrights
What did you do with them when you took them out????
gave them to my cousin who has a 98
  #23
Old 11-14-2010 | 11:17 AM
Damn.
I find myself in need of headlights.... both sides. The adjusters are broken, so when driving at night, it looks like I am looking for nickels on the roadway...... even with the high beams on.......
  #24
Old 11-14-2010 | 01:49 PM
SyKo450's Avatar
SyKo450
Damn.
Hence why I got headlights now lol
  #25
Old 11-14-2010 | 03:07 PM
SyKo450's Avatar
SyKo450
Question, what's the spindle lock nut torque supposed to be?
Specs say 195 ft/lb, reason I ask is because when I torque it to that, the rotor doesn't spin at all, is that how it's supposed to be??
  #26
Old 11-14-2010 | 03:39 PM
Two wheel drive, with bearings separate from the rotor? Then, you turn them finger tight, spin the rotor, tighten the nut some more, until you can no longer turn the nut by hand, then, I usually give it another quarter turn, and stick the cotter key in there.
If you have torqued it to 195ft/lbs..... I would replace the bearings and races.
  #27
Old 11-14-2010 | 03:51 PM
SyKo450's Avatar
SyKo450
Last weekend I torqued to about 120 and it spun some, the way you're telling me seems about right because the first time I took the lock nut off, it pretty much was fingertight, seems scary but I'll trust you with my life
  #28
Old 11-14-2010 | 04:21 PM
redheadhunter21's Avatar
redheadhunter21
x2 on heyyou, cotter pin keeps you from losing any parts so make sure you use a new one too
  #29
Old 11-14-2010 | 04:39 PM
SyKo450's Avatar
SyKo450
Can't find any dust caps, I need new ones!
The ones from the old rotors fit the new rotors a bit loose
  #30
Old 11-14-2010 | 04:51 PM
dodgeram07's Avatar
dodgeram07
do not TQ to 120!!! bad bad bad things will happen
x3heyyou
Quick Reply: Here's my beater!
