Vapor Canister
Old Jul 25, 2011 | 07:38 PM
LilBluRam's Avatar
LilBluRam
Default Vapor Canister
I have 94 ram 318, been having problems with the motor flooding out. finally found the source, no vacuum to fuel regulator. i have vacuum to vapor canister but not from the canister. looking to replace the vapor canister but cant find one anywhere...any idea what it could hurt to bypass vapor canister? any advice helps...
Old Jul 25, 2011 | 09:56 PM
JackJ's Avatar
JackJ
You will never pass inspection again with out it, I replaced one not to long ago on a Grand Cherokee, was a dealer only part. Cost right at $100.00
BTW the Cherokee had a 5.2 in it, so parts should be about the same, when you call the dealer have the VIN handy depending on year and when it was made within that year may depend on what one you need.
Old Jul 26, 2011 | 03:51 PM
LilBluRam's Avatar
LilBluRam
Oh I'm not worried about that we don't get inspected here I just need to know if it would hurt anything to bypass the vapor canister and run vacuum straight to the fuel regulator
Old Jul 26, 2011 | 03:58 PM
Yes, it will. You will be applying a vacuum to your gas tank, which is NOT what you want to do. That will work the pump harder, and possibly smoke it. Not to mention that you will constantly be drawing gas vapors into the engine, which will upset a few other systems.....
You have a vacuum line to your fuel pressure regulator? So far as I know, fuel pressure on these trucks isn't vacuum modulated......
If you are running rich, I would take a look at how old your O2 sensors are, and also see what your coolant temp sensor for the PCM thought the temp of the engine was.
Old Jul 26, 2011 | 05:25 PM
LilBluRam's Avatar
LilBluRam
Its got vacuum from vapor can to fuel regulator but vapor canister is plugged up and not putting out any vacuum
Old Jul 26, 2011 | 06:01 PM
JackJ's Avatar
JackJ
All those are is a a can with charcoal in them, over time they get to wet and full to work. Replace it.
Old Jul 26, 2011 | 07:12 PM
If it is sucking gas into the cannister..... just plug the line that goes to the tank. It goes to the rollover valve, not the pressure regulator. These systems are not vacuum modulated. (at least, nothing I can find in the service manual points to that....)
Old Jul 27, 2011 | 01:10 PM
LilBluRam's Avatar
LilBluRam
The line goes to the regulator...otherwise what else could cause my engine to keep flooding out?
Old Jul 27, 2011 | 02:25 PM
Failing coolant temp sensor. (the two wire guy on the drivers side of the thermostat housing, the one on the passenger side is for the gauge in the dash.)
Old Jul 27, 2011 | 02:44 PM
LilBluRam's Avatar
LilBluRam
That sensors gone I broke it when I rebuilt the motor but how does that affect my fuel pressure?
