Alarming experience driving my 2500 Ram in the snow for the first time.
Old Nov 30, 2011 | 08:41 PM
dsertdog56's Avatar
dsertdog56
My truck is pretty slouchy in 4hi, I attribute that to crappy gearing /big tires and driving one more axle. In 4 lo it's awesome.
If I could drive 40 mph steady I would not be in 4wd, there shouldn't be a reason. You can always pull the t-case lever down when you need it. I use 4wd like a compression brake so I don't slide.
But if your rings are toast and you have no power (only diesels like to burn oil) it would certainly be a contibuting factor
Old Dec 1, 2011 | 07:55 AM
kadetklapp's Avatar
kadetklapp
I'd like to just test the catalytic converter theory and hack the cat right off. I know it's not the most ethical thing to do, but staring down the barrel of the holidays I don't have a whole lot of options $ wise to spend $150 on a cat and $350 on a shop to install it. Under this truck there is not a whole lot of playing room for hacking it off, however. I'm not sure wtf to do here. I certainly don't want to cause any more harm to whats left of the engine.
Old Dec 1, 2011 | 10:10 AM
Sawzall will knock it off pretty easy.
Old Dec 1, 2011 | 10:19 AM
crazzywolfie's Avatar
crazzywolfie
couldn't you just drill a hole in the cat for now? i remember my neighbor doing that when his cat clog.
Old Dec 1, 2011 | 11:48 AM
Archion's Avatar
Archion
Pull the front o2 and see if it runs better, that will relieve pressure if there is any. And a cracked head on these motors doesn't always leak or lose coolant. They love to blow between cylinders.
Old Dec 1, 2011 | 11:51 AM
kadetklapp's Avatar
kadetklapp
well that would explain where the oil is going then...
Old Dec 1, 2011 | 03:07 PM
Wombat Ranger's Avatar
Wombat Ranger
Dad's v10 QCLB was a hoot to drive in the snow! Went anywhere, sideways or not. What's keeping you from droppin in another 360?
Old Dec 1, 2011 | 03:21 PM
Ramcountryboy's Avatar
Ramcountryboy
Last winter I drove my dad's 99 360 2500 4x4 QC/LB w/ 33's through the storm of the century (Im talkin drift on the highway higher than the floor boards) and that thing did awesome, I felt invincible lol!
Old Dec 1, 2011 | 03:41 PM
kadetklapp's Avatar
kadetklapp
The fact that it would be another 360...
Thinking about looking for a deal on a 12 valve first-gen Cummins to swap in, but haven't gotten brave enough.
Old Dec 1, 2011 | 09:48 PM
Wombat Ranger
That'd be pretty sweet! Could be done pretty cheap too, especially with a manual behind it. Then no computer controlled anything.
