wiper delay not working?
Old Dec 29, 2011 | 07:35 AM
piemxzhome's Avatar
piemxzhome
Default wiper delay not working?
Ok so i have a 97 ram 1500 with power door locks and power windows. My wipers only work on hi and low the delay wipers dont work and the power locks dont work either . I think it is the central timing modal because the tail lights dont work. Can any one help ?
Old Dec 29, 2011 | 08:22 AM
kfbryant1's Avatar
kfbryant1
not very good at chasing down electrical things, but check the obivous first. the fuses and relays, the ones in the cab and the ones under the hood. also I would think that if ya wipers work on high and low, then maybe the switch may be bad, for the others, I would look at the fuses. Good Luck someone with more knowledge will jump on here later
Old Dec 29, 2011 | 10:09 AM
Either the switch, or the smart part, which I believe is on the motor. On mine, if you tilt the steering wheel up to far, the wipers ONLY work on High.
Old Dec 29, 2011 | 10:12 AM
kadetklapp's Avatar
kadetklapp
Mine if you try to shut the wipers off during movement they get stuck in whatever position they are in on the windshield instead of returning to the down position. Logic board is my guess.
Old Dec 29, 2011 | 11:35 AM
piemxzhome's Avatar
piemxzhome
It's the same with my wipers they don't park down the bottom of the wind shild but I was think of trying an extra pulse intermittent wipe control box
