Bullspit!!!
Old Feb 7, 2012 | 11:58 AM
BigBlue83's Avatar
BigBlue83
Yes that was a typo on my behalf its A518 are they same ?
Old Feb 7, 2012 | 12:02 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
http://en.wikipedia.org/wiki/TorqueFlite#A518
The A518, later 46RH (hydraulic controlled governor pressure) and 46RE (electronic controlled governor pressure), is an A727 derivative with overdrive. Starting in the early 1990s, it was used in trucks and vans. The overdrive fourth gear ratio is 0.69:1.
Gear ratios:
1 2 3 4 R
2.45 1.45 1.00 0.69 2.35
Applications:
Dodge Ram pickup and vans 1500/2500/3500 V8 engines (DGT)
Dodge Dakota R/T (1998-2003)
Jeep Grand Cherokee 1998 5.9L
Jeep Grand Cherokee 1993-1995 5.2 V8
46RH
A renamed A518. A727 with overdrive and hydraulic control.
Applications:
1994-1995 Dodge Ram 2500/3500 V8
1993-1995 (Jeep Grand Cherokee 5.2)
1995 Dodge Dakota 5.2l magnum v-8
1995 Dodge Ram Van 2500 5.2L Magnum V8
46RE
A renamed second-generation A518. A727 with overdrive and electronic control.
Applications:
1996 Dodge Dakota V8 (Also 98-03 Dakota 5.9L R/T)
1996-2002 Dodge Ram 1500/2500/3500 V8
1998-2000 Dodge Durango 5.9L V8 (4WD or 2WD)
1998 Jeep Grand Cherokee 5.9L V8 (4WD)
Old Feb 7, 2012 | 12:05 PM
BackwoodsRam's Avatar
BackwoodsRam
a 518 is a catch all term for the 46rh/re
Old Feb 7, 2012 | 12:31 PM
gdstock's Avatar
gdstock
Blue, offer him $75 or $100, telling him that is has to be rebuilt and is worth $0.00 as it is. The 46re is what you need.
Rebuild it, get a new TC, and slap that puppy in when you get it done. It is not that difficult to rebuilt. Limitation will be $ to upgrade such as frictions and VB kit like Sure Cure, But these are not absolutely necessary.
You seem to be very resilient and motivated to get things done. You can do this.
Old Feb 7, 2012 | 03:14 PM
stewie01's Avatar
stewie01
Originally Posted by Wh1t3NuKle
I think he may be saying A518. I believe they are "similar" but don't take me on that.
I thinkin' A518 is just another name for the 46RE, looking at tranny parts on Napa's website the 46RE is listed as the 46RE/A518
Old Feb 7, 2012 | 03:48 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Kinda missed post #12 eh?
Old Feb 7, 2012 | 04:20 PM
97tn4x4's Avatar
97tn4x4
The a518 is our trans, just the model number itself. I'm in that finacial flood now and I'm waiting for the sun to shine myself. It sucks but I try to stay positive.
Old Feb 7, 2012 | 04:36 PM
LegendKiller89's Avatar
LegendKiller89
Okay between all this jargon have you been able to verify if 3rd and 4th gear work or not? If it's just that it does not come out of first it could be something different I'll touch on this later. Okay, stop, breathe and think. When you take off and it starts to rev up to 4k rpm did you take your foot of the accelerator? If so then did it go into 2nd?
I had this problem, and it was the forward gear band anchor. Drop the pan and see what it looks like. Dipstick don't mean much, it's a lazy indicator dropping the pan is going to allow you to see whats up.
Old Feb 7, 2012 | 04:59 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1..... And not to mention the Gov Solenoid and Gov pressure switch probably just need to be replaced.
Old Feb 7, 2012 | 05:09 PM
BigBlue83's Avatar
BigBlue83
o.k i am home now... kinda using my phone at work is frowned upon...
I havent driven on the high way yet, however i have gotten up to 60 miles an hour. yes when it rev. to 4k it changed gears by itself i did not ease off the gas. However at times it doesnt change, other times it changes around 3k. today at lunch it only paused briefly before changing gears, i only noticed it because its my truck i know how it feels. its sporadic shifting
