95 ram with code 27 problem
Old Mar 13, 2012 | 09:00 PM
plymouth43's Avatar
plymouth43
Default 95 ram with code 27 problem
I have a 95 dodge ram that has a code 27 showing. I can not find the problem after checking wiring with noids, hom meter and visual inspection. It has new injectors and a remand computer. There appears to be no reason for this code. Please help
Old Mar 13, 2012 | 09:23 PM
Erm, from what I am finding code 27 is "No Manifold Absolute Pressure Change"... isn't it? That would imply a failed MAP sensor, or a hole in the vacuum line for it. (or it may simply be unplugged.)
Old Mar 17, 2012 | 06:52 PM
plymouth43's Avatar
plymouth43
Default hey you
i got your reply to my post on the 95 dodge ram code 27. what dodge says is that code 27 is injector driver circuit which is off of number 4 injector number 4 cyl. i put a new engine in,cranked it up. it ran about 2 mins and blowed the auto shut down relay.i can't fix the code.
Old Mar 17, 2012 | 07:10 PM
gdstock's Avatar
gdstock
A little more info like engine, trans, 2wd or 4wd.....would make things easier.....
What do you know about the "new" engine...is it really new?
Old Mar 18, 2012 | 02:29 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Download the 95 service manual from the DIY/FAQ section and trace the #4 injector wire back to the PCM. Check the connector on the injector and the plug at the PCM.
Old Mar 20, 2012 | 10:43 PM
gdstock's Avatar
gdstock
Can you get it to run?
If so, while it is running, pull the connector off the #4 injector. Does it run the same or get worse?
Next, swap #4 injector with one on the other side of engine (becase the one on pass side have less crap in the way). Start engine and see if the problem moves. I suspect that the injector may be clogged or otherwise nonfunctioning or wiring to injector had a bad spot in it.
If the problem moves after swapping injector, the injector is suspect. If the problem stays on #4, then it is wiring or control to injector. As mine is a 99, I do not know how injector is fired on a pre-OBDII engine. The service manual that zman referenced should help narrow that down.
Hope this helps you get a little closer.
