passenger side floorboard is always wet?
Old Apr 12, 2012 | 08:21 PM
JEMRAM's Avatar
JEMRAM
Default passenger side floorboard is always wet?
what would cause my floor board to be wet?
Old Apr 12, 2012 | 08:23 PM
A leak.
Smell it, if it smells like coolant, it's your heater core. (rather common on these trucks...) If it smells like anything else, probably a water leak along the rear window, or third brake lite.
Old Apr 12, 2012 | 09:59 PM
SilverSS's Avatar
SilverSS
Could also be the air conditioner not draining. Mine would get the floor wet if I didn't stop for 20 minutes or so. I took a piece of hose and bent a 90* angle in it and stuck it onto the end of the drain for the A/C. No more problems. Check to make sure it's not clogged also.
Old Apr 12, 2012 | 10:49 PM
gdstock's Avatar
gdstock
I had this same problem as well. Double chek on the clogged thing. Dust accumulates and turns to mud....
Old Apr 12, 2012 | 11:08 PM
dodgeramit_10's Avatar
dodgeramit_10
+1 in my A/C class we just talked bout that a couple days ago check the drain tube
Old Apr 13, 2012 | 08:12 AM
seaham358's Avatar
seaham358
If your not using the AC you wouldn't still get the water would you? I ask because I have the same problem. Caulked around the 3rd brake light and that solved 1 water problem but I still get water under the flood padding up under the dash and its not the heater core.
Sorry for the hijack...
Old Apr 13, 2012 | 10:04 AM
Augiedoggy's Avatar
Augiedoggy
AC turns on when you use the defrost option on many vehicles so if this is one one of those....
Old Apr 13, 2012 | 10:07 AM
On the 98 and newer trucks, the only time the compressor ISN'T running, is if you have the vents set on heat...... On the older trucks, you actually have to turn the fan control to the a/c side, to get it to kick on.
Old Apr 13, 2012 | 10:09 AM
kfbryant1's Avatar
kfbryant1
also check under the passenger door on the very bottom of the truck, there are some drain vents that get clogged. stick a screwdriver in and clean them out. this happened on mine.
Old Apr 13, 2012 | 12:32 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The 3rd brake lite is also notorious for leaking. And the rear rubber roof seals.
pic courtesy of dodgeram01 i think.
