99 Dodge 318 engine build questions.
Old Apr 23, 2012 | 12:36 PM
snocross2xtremes's Avatar
snocross2xtremes
Default 99 Dodge 318 engine build questions.
Here a little back ground on my truck
99 dodge ram 1500 62K miles
custom lift kit sitting around 6 inchs with 40" irok tires
Dana 60 front axle and dana 70 year axle both locked and have 4:56 gears
nv3500 trans
center force clutch
As for my engine build
its a 318
after market plenum gasket installed
stock after market heads that are gasket match
.30 over with hyper tech pistons
comp cam part number 20-745-9
shorty headers
2.5 exhuast to 40 searis flow master then 3 inch out
nx wet nitrouse kit for efi 150 shot.
Now for my question
i have beening trying to deciced witch rout to go with tuning?
i have talked to BG Chylers a few times then can tune me to ecm one for nitours and one for with out. they want 500 bucks pluse a second ecm that will me around 100...
i also have been looking at the sct programers that cost around 400 but i dont really know much about them or have been able to talk to anyone who does...
Any help would be great!
Thanks
Joe
Old Apr 23, 2012 | 02:09 PM
Talk to Sean at Hemifevertuning. Custom tunes are 365.00 with unlimited updates. Give him a call, have a chat, I would bet he can get you taken care of.
Old Apr 23, 2012 | 02:32 PM
damian2000's Avatar
damian2000
ya try hemifever hes the best at this and will get you set up with everything you need
Old Apr 24, 2012 | 06:12 AM
snocross2xtremes
Sent him a email thanks guys
Old Apr 24, 2012 | 02:09 PM
gdstock's Avatar
gdstock
I'm just curious......Why do you need a rebuild after only 62K miles?
Old Apr 24, 2012 | 11:36 PM
QuadCabLuv's Avatar
QuadCabLuv
Sweet f'n truck man!!!
Old Apr 25, 2012 | 07:41 AM
snocross2xtremes
Original owner drove it with bad plenum gasket for a long time
Old Apr 25, 2012 | 07:42 AM
snocross2xtremes
Thanks!
Also i ordered my sct last night!!
Old Apr 25, 2012 | 02:11 PM
gdstock's Avatar
gdstock
If that is all that is wrong, rebuilding may be more expensive than what is needed. Replacing plenum gasket, water pump, cat, and timing set should do it, unless there are other issues in the lower end as well.
Rebuilding engines in the 70's was not that expensive....but something drastic has happened between then and now!
Old Apr 25, 2012 | 02:24 PM
stewie01's Avatar
stewie01
Electronic's? And the overall cost of everything......
