Wheeling a fullsize
#1093
Ordered the EQ Heads from Clearwater directly. Pair fully assembled with 1piece SS valves and springs for lift up to 0.5 which is fine for the camshaft I installed back in 2012. Keeping the stock 1.92 size for torque. Will make it simple and use HS 1.6 non-adjustable/pedestal mount roller rockers. Get new stock push rods.
A couple weeks for them to arrive.
In the meantime, got the Art Carr / Winters shifter installed. Just need to tidy up with some side panels for some accessories.
Some mockup install spots
Final spot
Fabbed some brackets that allowed use of factory linkage
Basic frame for the shifter housing to slide over and secured with easy access side bolts.
Perfect reach and still close enough when the half doors go on.
Don't have to touch the steering column at all. Still use the O/D button.
Final spot
#1094
#1095
None of that is beer worthy in the grand scheme of things. Thank you for considering the items in the queu.
Yes it is.
