Wheeling a fullsize
#181
the s10 using the push button shifter activates the vacuum valve to move the actuator witch moves the cable for the axle shifter it still holds the actuator in place while in 4wd
basically the same setup
#182
the s 10 switch is the same idea as the t case vacuum switch, the only difference is our switch in the t case is a manual switch when we move the shifter
This would move (and hold) the CAD in one direction when activated.
What would move (and hold) the CAD in the opposite direction when deactivated?
Our system swaps vacuum from one side of the CAD to the other, and vents the opposing side.
Our switch has four ports, and the CAD has two lines, not one.
#183
Did a quick check of my system to be sure as well as catch anything since the last trip. Put up the front end on jack stands and put tranny in Neutral.
It actually switches b/t 2 and 4 instantly for mine. Red line is for 2wd.
Just as Spillage said there is a 4 port switch: http://dodgeram.org/tech/repair/4X4/4x4_engagment.htm
So while that switch I linked was the first that came up for "vacuum actuator switch" I hope to find one that is applicable. If not, then possibly simple compression lines and a tee or something. I could not get in a position to see the actual switch as it seems to be located on top of the tcase.
Again, this was an idea and seeing it talked out in a bit of detail helps.
Edit: Picked up the Dana 80 shafts to be used in the Dana70. 35 spline factory yo.
#184
oooo interesting but pricey
http://www.genosgarage.com/BD-2-LOW-...fo/BD-1030703/
here is what our tcase switch is, ball valve to switch the flow --
pn 53001101
https://www.carpartsdiscount.com/aut...tml?3593=45385
pn 53001101
![](https://www.carpartsdiscount.com/auto/archive/pictures/45385/515/1/P/AB26BE9/dodge_ram_1500_2000_transfer_case_switch_oem_600_553_600553.jpg)
#185
#186
#187
I can let the front DS hang 3"-4" past where it is now then I am in big trouble. So clocking down about ??? 2" I think. For the street it works fine but if I go play (which we might this winter) I don't need this to be a hassle on the trail and in deep snow. I will take pix bud not a problem.
