Wheeling a fullsize
Old Jul 27, 2012 | 08:46 PM
  #31
Goatley's Avatar
Goatley
Nice build I might copy your bumper though.
Old Jul 28, 2012 | 12:59 AM
  #32
Wh1t3NuKle's Avatar
Wh1t3NuKle
Default ORE Fuel Tank Skid
If you haven't seen one, then here you go. Nothing special, as expected, as it's fiberglass with porky stamped steel brackets. Naturally the way they are stamped makes them more prone to bend. Somewhat makes sense to allow some give.
This will make a good template for making a new one that is much more stout.
Old Jul 28, 2012 | 01:13 AM
  #33
gdstock's Avatar
gdstock
It looks more like ABS plastic instead of fiberglass. ABS is less priong to breaking when impacted than FG, but harder to patch.
Old Jul 28, 2012 | 01:18 AM
  #34
Wh1t3NuKle's Avatar
Wh1t3NuKle
Does ABS plastic have fibers like FG? Or itch upon touching?
Old Jul 28, 2012 | 01:25 AM
  #35
gdstock's Avatar
gdstock
ahhh. No. I haven't crawled under and looked though. Surprising to me they usde fg. Doesn't flex much...but with fibers, it must be. My Yota has steel, but not concerned on my Ram as it is 2wd...and unless somthing goes against any known plans, won't ever be off the road!
Are you going to fab a steel one to replace on yours? Looks like you need more protection to keep from rupturing tank.
Old Jul 28, 2012 | 08:36 AM
  #36
stewie01's Avatar
stewie01
But off-roading a 2wd is fun..., until you bottom out on the transmission pan
However, your's is just getting too pretty to take off road...
Old Jul 28, 2012 | 12:56 PM
  #37
Wh1t3NuKle's Avatar
Wh1t3NuKle
The offroad edition trucks have these skids afaik. You're binky 2wd wouldn't care.
Better brackets and skid will be combo steel and high density plastic (i.e., cutting board). Some research to do....
Old Jul 31, 2012 | 12:02 PM
  #38
Wh1t3NuKle's Avatar
Wh1t3NuKle
Couple more pics from the trip and showing the side flopper. Helped for some good chit chat, reminder of proper spill cleanup (shoveled contaminated dirt into bucket and hauled out), and comms with other rigs going in/out.
I think we went through 5 ppl just hacksawing the tube fender off! Was a hot day.
Old Aug 24, 2012 | 06:15 PM
  #39
Wh1t3NuKle's Avatar
Wh1t3NuKle
Hitch will be sucked up and tied in.
Old Aug 24, 2012 | 07:57 PM
  #40
stewie01's Avatar
stewie01
You got some mad fab skills man! Looks great.
