Wheeling a fullsize
Old Nov 24, 2021 | 01:18 PM
  #1191
Wh1t3NuKle's Avatar
Wh1t3NuKle
Means there is no front driveshaft.
Old Nov 28, 2021 | 06:43 PM
  #1192
adukart's Avatar
adukart
I just ordered a shackle flip kit, trying to help my axel wrap in the soft stuff by deleting the block. I was wondering who knows of a good way/parts to flip the u-bolts when deleting the block?
Old Nov 28, 2021 | 07:55 PM
  #1193
I think there is a kit out there for that as well......
Old Nov 28, 2021 | 08:00 PM
  #1194
adukart's Avatar
adukart
Only one I have been able to locate is the dodge off road. $175 seems a little steep to me.
Old Nov 28, 2021 | 08:05 PM
  #1195
Indeed. All it is is a couple plates to put the u-bolts through..... I would hope for that kind of money, it came with the u-bolts as well??
Old Nov 29, 2021 | 01:55 PM
  #1196
adukart's Avatar
adukart
That kit does come with the bolts. I just need to get under my truck and do some measuring I think. I can get the plates cut by the local steel supplier and I have a drill press. The bolts are the hard part, I also need to look at the pack and see what I need to do for the centering pin.
Old Nov 29, 2021 | 10:57 PM
  #1197
Wh1t3NuKle's Avatar
Wh1t3NuKle
Don't waste on DOR.
Shackle flip requires a zero rate or offset block and degree shims. Zero rate has holes to reposition axle with center pin. The lift is only happening at rear mount, so the shift to recenter in wheel well, then shim to account for pinion angle change if still stock driveshaft with tcase slip yoke.
if still 1500 leaf springs, then 2.5" width
https://www.offroaddesign.com/angled...e-springs.html
https://www.offroaddesign.com/axle-o...hick-pair.html
https://www.offroaddesign.com/suspen...rsal-kits.html
Other places offer similar above. I made my zero rates. Ubolt flip kit from RuffStuff. Measure tube diameter.
Old Nov 30, 2021 | 01:46 PM
  #1198
adukart's Avatar
adukart
Originally Posted by Wh1t3NuKle
Don't waste on DOR.
Thank you for the response, it is a 2500 but has old skyjacker lift springs in the rear, which are way to soft but I'll save up for some decent leaf springs eventually. The kit I got is the apoc industries which replaces the front mount as well. The front one has multiple slots to help center it. I think though from what you showed I can get the rest of what I need with a few measurements. Thank you.
