Water pump and efan install.
Old May 27, 2012 | 01:52 PM
  #31
QuadCabLuv's Avatar
QuadCabLuv
Originally Posted by gdstock
Tap the power side of realy to the power input post on PDC. Then there is a small red wire from the firewall to the PDC that is only hot when the key is on. You can take that to the high side of control side of relay.
Im having a hard time locating that small red wire. Does it come out the pdc in that large harness? If so i see several red wires
Old May 27, 2012 | 02:10 PM
  #32
gdstock's Avatar
gdstock
Yes. The large budle of wires. I think it is 16 ga. Find one that is only hot when key is turned on.
Old May 27, 2012 | 02:20 PM
  #33
QuadCabLuv's Avatar
QuadCabLuv
ok great. now if i can just find that ignition wire....
Old May 27, 2012 | 02:39 PM
  #34
gdstock's Avatar
gdstock
Poke it with a tester and have someone turn key on and off. Don't skin wire back - problems after!
Old May 27, 2012 | 02:50 PM
  #35
QuadCabLuv's Avatar
QuadCabLuv
I thought i had found it. seems to be the only solid red wire there. but when i tapped into it i discovered it was a constant. I dont have a volt meter or tester handy....
Old May 27, 2012 | 04:26 PM
  #36
EndIsNear's Avatar
EndIsNear
Ignition switch might be a blue or a black and white wire too from what I researched.
Old May 27, 2012 | 05:10 PM
  #37
Wh1t3NuKle's Avatar
Wh1t3NuKle
I didn't read the whole thread.
Ignition wire is BLUE as shown in this pictures. I have a white pigtail spliced to it.
Maybe this is helpful to you.
Old May 27, 2012 | 05:15 PM
  #38
QuadCabLuv's Avatar
QuadCabLuv
ohhh no wonder the red wire didnt work...lol
that pictures helps alot!!! Im gonna go look for it now.
Old May 27, 2012 | 05:16 PM
  #39
Wh1t3NuKle's Avatar
Wh1t3NuKle
Sorry, meant to agree with you on that.
You can verify the wiring with the diagrams in the FSM. Haynes was not helpful to me on this one.
Old May 27, 2012 | 06:48 PM
  #40
gdstock's Avatar
gdstock
Dang! Theat's the photo I was looking for! I could not remember who posted it and I got colors mixed up. Done too much wiring lately to keep it all straight. Oldtimers thing.
