01 2WD prerunner lift
Old Jul 8, 2012 | 06:04 PM
cntry_prernnr's Avatar
cntry_prernnr
Default 01 2WD prerunner lift
ok so how does this sound?
I have my lift all picked out:
Fabtech 6.5 in the front
bilstein 5160's on all 4 corners
and a BDS shackle flip in the rear.
my only problem is i cant find a shackle flip anywhere.
Old Jul 8, 2012 | 06:07 PM
cntry_prernnr
can any one help me?
Old Jul 8, 2012 | 06:38 PM
Links to the products you have chosen please?
Check top guns customz for the shackle flip.
Old Jul 8, 2012 | 07:02 PM
Matt Nickerson's Avatar
Matt Nickerson
Yeah, the shackle flips are hard to find.
Doesn't specify 4wd or 2wd but I guess it would work for both?
these are 4" shackle flips:
http://www.dirtyparts.com/store/deta...-KIT/pid-78029
...or call your local BDS distributor and have them order it for you.
http://bds-suspension.com/distributor-lookup
If you need zero rates here's a good place to get 'em:
http://www.jkwoffroad.com/offroadproducts.php
edit: is your ride an ext cab? I'm only seeing Fabtech 6.5" lifts for ext cabs...just a note.
Old Jul 8, 2012 | 07:05 PM
cntry_prernnr
i will only be using the front portion of the lift (no fab. shock absorbers or rear lift)
http://www.fabtechmotorsports.com/pr...ay=DODGE%202WD
http://www.xloffroad.com/index.php/F...te-System.html
http://www.bilsteinus.com/products/l...reservoir.html
http://www.topguncustomz.com/p-9936-...er-system.aspx
(top guns shackle kit is for a 4wd but i can only use the rear since im only 2wd)
Old Jul 8, 2012 | 07:06 PM
cntry_prernnr
TY so much!
Old Jul 8, 2012 | 08:42 PM
cntry_prernnr
yes mine is an ext. cab, and do i need just a zero rate or do i need degree shims as well?
Old Jul 8, 2012 | 10:12 PM
EndIsNear's Avatar
EndIsNear
Doestch-Shocks is also a good company for 2wd lifts. Might be cheaper than Fabtech, and possibly better quality.
Old Jul 8, 2012 | 11:02 PM
cntry_prernnr
i only need hardware for front im using bilstein 5160's on all 4 corners n a shackle flip in the rear.
Doestch-shocks is cheaper yes but quality i dont know too much about this company.
