5000lb winch
Old Aug 6, 2012 | 04:14 PM
kejobe's Avatar
kejobe
Originally Posted by Ram3602500
Whats the block for?
This right here:
****** block, and double line it. (winch cable goes from winch, thru pulley attached to load to be moved, and back to your truck.) It slows things down, but, doubles the pulling power of your winch.
Old Aug 6, 2012 | 04:44 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
It's called a s_n_a_tch block. Block and Tackle method of multiplying load. Some images to help you out.
However, you only real use these if the access to the recovery is not straight on or some other obstruction.
For snow stuff like you are intending, these are not typically needed/used. Very dependent on the recovery and so while it's a good tool to have in the bag, it isn't to be used for every situation. You also need to be careful _HOW_ it's used. You don't want to overload the winch, nor overload the recovery vehicle if it can't handle the load (e.g., proper recovery point). Most vehicles its safer to put tow strap around axle tube, then shackle, then tow strap and tow. Or put the winch cable to the shackle.
Do some searching on recovery techniques to see other options.
Old Aug 6, 2012 | 05:06 PM
Hahns5.2's Avatar
Hahns5.2
If you use a sn@tch block in those situations you aren't doubling your pulling power. You attach the block to the anchor and run the cable through it and hook it back on the vehicle, thus doubling your pulling power. Also the more cable ran out of the drum the more power you get as well.
Old Aug 6, 2012 | 08:33 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Originally Posted by VWandDodge
Ain't geometry and physics wonderful?
Uhhhhhh -- HELLO! Am I one of the few who was required to take science and math in high school?
Old Aug 6, 2012 | 09:09 PM
dhvaughan's Avatar
dhvaughan
watch at 0:35 for a lesson in arithmetic
Old Aug 6, 2012 | 09:20 PM
****** block. Basically, it's a pulley with an eye hole. The idea is, you put the block on a hook (or whatever) on the load to be pulled, run your winch cable around the pulley, and back to your truck. It cuts line speed in half, but, doubles pulling power. Makes your winch a 10,000 pound pull.
Old Aug 6, 2012 | 09:24 PM
Hahns5.2's Avatar
Hahns5.2
Old Aug 6, 2012 | 10:32 PM
Ram3602500's Avatar
Ram3602500
cool thanks for all the info guys I appreciate it
Old Aug 6, 2012 | 10:47 PM
gdstock's Avatar
gdstock
ROFL! I guess that slipped by everyone. I was intentionally NOT going to make any reference to "you'all got skools in Okiehoma!"
Old Aug 7, 2012 | 08:30 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Born in Wisconsin and grew up in Illinois, thankyouverymuch.
