Deep water, stock?
Old Sep 12, 2012 | 10:56 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Default Deep water, stock?
Just out of curiosity, how much water can we ford in our trucks stock? Not sealing anything up special, no lifts, etc....
Just wondering is all..
Old Sep 12, 2012 | 11:01 AM
Arde's Avatar
Arde
Normally you can go until water reaches the fan if you don't have the ability to turn it off.
Old Sep 12, 2012 | 11:16 AM
But, if you go into water deeper than the axles, make sure to check the fluid when you come out......
Old Sep 12, 2012 | 11:38 AM
dodge dude94
Deeper than the axles?
As in over? I figured I should check the fluid if it hit the vents but why just over? Bad habit of water leaching in?
Old Sep 12, 2012 | 11:46 AM
The seals are designed to keep diff lube IN, they aren't always up to the task of keeping water OUT, when they are submerged.
Old Sep 12, 2012 | 12:38 PM
FireDodge's Avatar
FireDodge
Yeah I got a little too cocky once and ended up to my front headlight in mud at an angle, when I did gears this spring the fluid was a little dirty to say the least...
Old Sep 12, 2012 | 01:05 PM
crazzywolfie's Avatar
crazzywolfie
some good advise. you don't want to go too deep
this
caused this
Old Sep 12, 2012 | 01:31 PM
dodge dude94
And how does one seal the diffs for proper use then?
Old Sep 12, 2012 | 01:35 PM
Good seals, and not with 100K miles on them.... and run the vent hose up just as high as you can get it.
Keep in mind, on our trucks, the trans vent is at the top of the pump housing, IN the bellhousing. Going into water deep enough to get the t/c wet, pretty much assures you that you are going to have water IN the trans.... never a good scene. (and a **** poor design for a 4x4.....)
Old Sep 12, 2012 | 01:37 PM
dodge dude94
Alright. I guess I just won't drive through water right now.
Not like I need to anyway, I was just wondering.
