building a most fuel economic ram 1500 5.2L
#21
It's all good.
#24
#25
guys i raise the temperature by adjusting the electric fan control to turn on the fan at 205 degree not changing the thermostat. so the truck is operating normal tem at highway, only hight tem at local. that is where i want to improve fuel economic on local drive. also the fuel max connect to imt sensor will fool the computer that it runs on hotter intake air temperature ,so meetering less fuel and change ignition timing.
#26
#27
on the plenum gasket leak i put cooper gasket compound on both side of gasket, after tied all the bolts i put cooper gasket compound around the plate and the manifold,since it is working on suction, anything inbetween the gap will help for leak. i don't know this will work or not , time will tell.
#28
Stocking2- did you replace the intake bolts with shorter ones or use a different pan?
Wombat 205* isn't really overheating. A lot of newer cars run 220*-230*. In my 95 Trans Am the low speed fans came on at 205* and kicked to high speed at 228*. Personally I don't like anything running that hot and all my vehicles have a 180* stat but they *should* be more efficient at higher temps.
Unreg- I'm with you on only buying the top tier gas- I usually get Chevron but sometimes Exxon or Shell. I
discussed this with a friend of mine who argued that a name brand gas station is only required to purchase a certain percentage of fuel from the brand they advertised- the rest of it comes from wherever. Any thoughts on that?
#29
#30
silverss, i used the stock pan and bolts, only thing i did is put cooper gasket compond on both side of gasket, thoes compond contains real cooper should raise the height of the gasket and give better seal, also i put the compond outside in between the pan and plenum, the vacumm will suck in the compond to fill in any gap it has. hope this works, i will check after next oil change.
