Decisions, what should I buy?
Old Mar 16, 2013 | 08:19 PM
  #21
gdstock's Avatar
gdstock
Originally Posted by Arde
Yeah, one of these,
http://www.walmart.com/ip/Grip-28580...Strap/15041387
If you have a truck, you probably have one laying around somewhere.
And if you use that to hold a gas tank in your truck, you need to be beaten......
Old Mar 17, 2013 | 01:02 AM
  #22
Wombat Ranger's Avatar
Wombat Ranger
1000lb weight capacity, I know my gas tank doesn't weigh that much. I don't see the problem as long as it is secured.
Old Mar 17, 2013 | 01:10 AM
  #23
gdstock's Avatar
gdstock
So rotting out would not be a problem? I just think anything short of fixing it correctly is foolish. For an emergency to get it home or something - that would be different.
Old Mar 17, 2013 | 11:12 AM
  #24
Wombat Ranger
Seems like rotting out was a problem with the metal straps, but nobody discourages using them. Haha.
Old Mar 17, 2013 | 01:17 PM
  #25
Ham Bone's Avatar
Ham Bone
I think I'll go down to the basement and make one with a couple strips of tin riveted together. I'll probably out some gorilla tape on it too so It doesn't run the tank reall bad.
And the stock gas tank straps rot out bad. The front tank strap looks awful but it's still holding, for now
Old Mar 17, 2013 | 03:30 PM
  #26
Arde's Avatar
Arde
My thoughts exactly. I've had ratchet straps that were were covered with oil and grease for years and were still as good as new. Under the truck, they are shielded from ultraviolet rays if that's even a concern. Can't imagine what a ratchet strap might do that a metal strap hasn't already done, and they're a damn sight cheaper and easier to replace if the need ever occurs.
Old Mar 17, 2013 | 08:58 PM
  #27
Ham Bone's Avatar
Ham Bone
I have two PCVvalves btw.
At least I think, there's something in the passenger valve cover too
Old Mar 17, 2013 | 10:38 PM
  #28
Arde's Avatar
Arde
Should just be a rubber grommet with a hose coming from the air cleaner box.
Old Mar 18, 2013 | 07:03 AM
  #29
Ham Bone's Avatar
Ham Bone
But what is it and what does it do?
Old Mar 18, 2013 | 08:12 AM
  #30
stewie01's Avatar
stewie01
^^ Lets it breathe.
