leveling kit
Old Apr 9, 2013 | 08:53 AM
zlowe712's Avatar
zlowe712
Default leveling kit
2001 dodge ram 1500 4x4 ext 360. I'm looking to buy a leveling kit for my truck today and I was wounderin what's a good brand? I was thinking about going with zone off road. I was gonna buy the 2.5 leveling kit and 2 front shocks that are set up for 2-3 inchs of lift. Good idea or what should I do different?
Old Apr 9, 2013 | 09:22 AM
stewie01's Avatar
stewie01
Hell Bent Steel makes some good stuff
Old Apr 9, 2013 | 11:13 AM
QuadCabLuv's Avatar
QuadCabLuv
You could also buy some coil springs from a 4x4 diesel, will net you 2" of lift and you gain a little more suspension travel than using the spacers.
Old Apr 9, 2013 | 12:07 PM
ChillyPhil's Avatar
ChillyPhil
Mine has 2.5" Hellbent Steel spacers on. It put my front about 1/2" higher than the back but I don't mind it.
Old Apr 9, 2013 | 12:33 PM
zlowe712's Avatar
zlowe712
I'll check out hellbent steel, do I need shocks also?
Old Apr 9, 2013 | 08:09 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Request to merge these threads.
https://dodgeforum.com/forum/2nd-gen...eling-kit.html
Old Apr 10, 2013 | 12:18 PM
ChillyPhil's Avatar
ChillyPhil
Nah, but it would be a lot better ride if you had better shocks. I'm getting the Skyjacker Hydro 7000s off Autoanything. Them spacers do make the ride alittle rougher, not much though.
http://www.autoanything.com/suspensi...A2623A0A0.aspx
I'm getting the front shocks with the 1-3" lift option (I think) since my spacers are 2.5" and for the rear I think it's like 0-5" lift option.
Old May 14, 2013 | 08:15 AM
joshram1500's Avatar
joshram1500
I have a 98 dodge ram 1500 4x4 and I am planning on installing a 2.5" coil spring spacer leveling kit. I understand I need to get longer shocks but on 4 wheel parts website it had a two differ options: front dual OE w/2.5" lift, and front w/o-2.5" lift. What is the difference and how do I know which one i need? Thanks!
Old May 14, 2013 | 01:28 PM
CSDavies26's Avatar
CSDavies26
either one will probably work, but i would get the ones that specifically say "w/ 2.5" lift"...i think the stock shocks technically will handle the 2.5 inch spacers but that may result in increased wear and poorer ride quality. I'd go with the longer ones.
