dodge to h2
Old Apr 28, 2013 | 10:46 AM
joycarpet's Avatar
joycarpet
Default dodge to h2
I am purchasing wheels an tires from a big dodge ram that i would like to install on an h2 hummer. will they fit?
Old Apr 28, 2013 | 10:57 AM
What's the bolt pattern on your H2?
Old Apr 28, 2013 | 11:21 AM
QuadCabLuv's Avatar
QuadCabLuv
I don't think they will work. for one I think the h2's are 6 lug.
Old Apr 28, 2013 | 11:33 AM
kejobe's Avatar
kejobe
If the Dodge wheels are 8 lug they MAY fit. Depends on the offset, backspace, and diameter whether or not they will.
A Google search provided the the 3/4 & 1 ton rams have 8x165.1 & so does the H2.
Old Apr 28, 2013 | 01:22 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The center bore is quite a bit bigger as is the stud size on the H2. I doubt it will work.
Old Apr 28, 2013 | 01:27 PM
redneck_ram's Avatar
redneck_ram
ive seen h2 wheels on a dodge before, but not vice-versa.
Old Apr 29, 2013 | 09:53 PM
Wombat Ranger's Avatar
Wombat Ranger
Same bolt pattern. Should fit.
Old Apr 30, 2013 | 01:22 PM
QuadCabLuv's Avatar
QuadCabLuv
May need a hub centric ring if the hub is to big on the wheel. The center of the wheel needs to fit tight on the hub otherwise you are putting all the strain on the studs instead of the wheel.
Old Apr 30, 2013 | 05:19 PM
zman17's Avatar
zman17
If I understand correctly, the op want's to put Ram wheels on an H2. The center bore is a lot smaller on the ram wheels, so without making said holes bigger, I don't see how they will fit.
