Should I get an Add A Leaf?
Old Jun 4, 2013 | 03:12 PM
EHS22's Avatar
EHS22
Default Should I get an Add A Leaf?
I put a 2" leveling kit on my 97 1500 4x4 about a year and a half ago and I thought it would level completely out but now she squats a little bit. I've been thinking about doing an add a leaf but I don't want it to nose dive like it did before. IMO I don't think it will. What do you guys think?
Old Jun 4, 2013 | 03:23 PM
Wow, that does sit pretty low in back..... is it even from side to side? (dodge lean?)
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
You might go for 1.5 in if there is one. Since it will be stiffer, the stiffness will lift the back by itself.
Old Jun 4, 2013 | 06:41 PM
SilverSS's Avatar
SilverSS
AAL would work fine. That's what I did to raise the back a little. Sorry I didn't measure how much. I used a short leaf and got the pair for $40. It does stiffen it up quite a bit also.
Old Jun 4, 2013 | 07:31 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
I think it's fine. That's my vote.
Old Jun 5, 2013 | 12:20 AM
EHS22's Avatar
EHS22
From what I can tell it sits even from side to side. I have a pic from the rear that I will upload tomorrow and you guys can tell me what you think. I'll probably go ahead and get the AAL.
Old Jun 5, 2013 | 11:38 AM
merc225hp's Avatar
merc225hp
I think you should get a tape measure out and see what's going on. The truck looks fine to me.
Old Jun 5, 2013 | 08:08 PM
redneck_ram's Avatar
redneck_ram
i have a 2" HD add a leaf in mine, and it does have a slight rake to it, but not overly so.
Old Jun 9, 2013 | 06:48 PM
EHS22's Avatar
EHS22
I measure from the bottom of the tire to the top of the back fender and the same for the front, correct?
Old Jun 9, 2013 | 06:50 PM
I'm not sure a 1.5" add-a-leaf would bring it up enough....Mine only raised it about an inch. Your springs may be weak.
