weekend warrior build.
Im wanting to make a build thread so here it is.
My truck :2000 dodge ram 1500quad cab 4x4
Motor: 318/5.2 100k when i bought 120k as of this post
What i have done to the motor
:new water pump new, timing chain and gears,new timing change gasket and thermostate.
New plenum gasket with new kegger bolts new belly pan bolts new t.b gasket new injector seals. (the doorman kit from autozone.) has new radiator new k&n air filter new ngk plugs, new wires dist cap and rotor(brass).new pcvand hose,new ignition coil.
Transmison: 46re/a500
It has had a full rebuild by a great local shop. All the goodies and a transgo full shift kit. 50k warrenty. Added a rv motor hone tranny cooler and delted my check valve. Also added apower steering cooler.
Suspension: rouch country full level kit.
2.5 inch coil booster up front 2 inch blocks in back four hydro 8000 exstended travel shocks. Also deleted front sway bar ( no adverse effects if you dont drive like an ***).also replaced thw wheel bearings the ball joints the trac bar and the u joints
Offroad accesories.
Two 55watt halogen trail lights up front.
Inside the truck :
Two 6x9 speakera from walmart up front and two 6.5 in subs in the back doors.
Soon to come:
Fix my very minor frame rot up front by sway bar mounts.
Add push bar and winch
Fix door rot
Tint drivers and passenger windos
Plasticolor mud flaps
L.s.d unit for rear end
Skid plates.
tires :
started with 265/75 cooper discoverer atr(quiet awsome in rain and snow).
then got 305/70 super swamper ssr (amazing offroad)
Current tires 285/75r16 cooper discovere st maxx(couldnt ask for more. Quiet great in rain great on road manners AMAZING OFF RAOD PREFORMANCE. Only thing it lacks in is thicks clay like mud they cake up quick bit with some spin clean right out for the most part i llve these tires
Pics soon to come and maybe some videos.
Offroad accesories.
Inside the truck :
Soon to come:
Fix door rot
Skid plates.
tires :
Trending Topics
have to get a computer before i upload pics and im not doing a frame swap i was ganna have a small rot spot on the front welded up hah. I decided not to since my mech told me it wasnt bad. I already coated it with a rust reformer (paint on type) them primer and paint and undercoat. It wont get any worse plus ita not big so why bother unless its getting worse. Ill try to post some pics from my phone but idk how to ? .
