Dana 60 Swap!
#151
Nope no air hammer. I've tried hitting with a BFH and socket+extension. The axle seal started coming apart before the hub would.
I'm about to the point where I'm gonna paint it as much as possible. Install bj on other side and just install the thing and then use the steering to pop it off
#154
ordered 250 dollars worth of moog premium and problem solver ball joints and u joints for the truck today from Rockauto
Moog K7394-Uppers
Moog K7397-Lowers
U joints
Front drive shaft- Moog 354
Rear drive shaft- Moog 330
Axle shafts- Moog 374
Haynes manual, probably should've got this long ago
total 254
Pretty good, pretty good
Moog K7394-Uppers
Moog K7397-Lowers
U joints
total 254
#157
Alright fellas it UPDATE time
I got the rear axle and rear drive shaft painted today and also got my U joints from Rock Auto in the mail
What i used as a degreaser. All I did was wire wheel, then soak it with this stuff, let sit for a couple minutes and then rinse it off the water hose. Just be careful not get in down the breather hole, i screwed the thing back in to stop stuff from going down in it.
Next here are my U joints, As you can see they are all Moog, all MADE IN USA, and all have grease zerks. They totaled around 130. Its every u joint on the drivetrain.
see the grease zerk in the bag?
first coat
second coat, I had enough left over to paint the driveshaft
how to be able to paint both sides
here is a before picture
all in all a succesfull half day. POR-15 really goes far. Think about how much you need, and then pour half the amount, and then pour half of that amount.
first coat
#158
