Dana 60 Swap!
Old Oct 17, 2013 | 01:55 PM
  #81
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
I'm not sure about anything. He's the one with the parts, I'm just making educated guesses.
Old Oct 17, 2013 | 01:58 PM
  #82
Ham Bone's Avatar
Ham Bone
You guys so sure about this info? remember the 2500's sit higher than the 1500's. The 2500 arms should be longer than the 1500 arms and thicker to boot.
Edit: You do have both sitting there get a tape out and measure them.
im at college, so theyre not with me right now but I can measure them tonight probably.
Old Oct 17, 2013 | 02:11 PM
  #83
merc225hp's Avatar
merc225hp
Deleted post, wrong info.
Old Oct 17, 2013 | 02:14 PM
  #84
dodge dude94
*scratches head*
But the longer one has that lip on the bottom like my 1500 control arms.
Old Oct 17, 2013 | 04:08 PM
  #85
Wombat Ranger's Avatar
Wombat Ranger
Merc are you sure the shorter arm isnt an upper?
Old Oct 17, 2013 | 04:33 PM
  #86
merc225hp's Avatar
merc225hp
^^^ I don't think so but I can go check to be sure, good point I just grabbed two arm's and took a pix of them Oops.
Edit; You are right Sir that smaller arm is the upper arm for a 1500, so ignore that pix/post. See you need to be here to fix my F ups.
Old Oct 17, 2013 | 04:50 PM
  #87
Ham Bone's Avatar
Ham Bone
The mystery continues!
Old Oct 17, 2013 | 04:54 PM
  #88
dodge dude94
Could to make a "long-ish arm" system by using four lower arms?
Old Oct 18, 2013 | 12:32 AM
  #89
Wombat Ranger
^^ No that would just F your caster up something horrible.
To clear up the cloudy confusion about my advise to Hammy. I believe that the frame control arm mounts on the 1/2 ton and 3/4 ton frames are in the exact same location. The wider d60 housing would then call for a shorter arm to locate it in the same place. My personal opinion is that they mounted the front axles about 2 inches too far back in these trucks. Nobody ever has problems rubbing tires on the front bumper. So if I had all the parts available like Cory does, I would use the 1500 control arms with the 2500 d60 and move it a bit forward of the stock location. Only maybe 1.5" max, no big deal, won't affect steering or anything. We did a 2" axle forward kit on an '01 24v at work recently and it solved the guys rubbing issues with no ill side effects.
Merc you are still 10 times more knowledgeable with these trucks than me.
Old Oct 18, 2013 | 12:39 AM
  #90
dodge dude94
Just a question, how is the steering, spring/shock, and drive shaft position and angles effected?
