snowboundrmk's 360 build
Old Aug 30, 2013 | 12:37 AM
  #21
snowboundrmk's Avatar
snowboundrmk
Ok cool that plenum plate will save me money. But why 1.7 rockers over 1.6? Don't the stock heads stop flowing at that much lift and won't it just wear the valve guides?
Old Aug 30, 2013 | 01:37 AM
  #22
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
If you're running a cam with more lift, the 1.7s might cause more wear. But if you're running a stock cam, those 1.7's ACT like a bigger cam.
Old Aug 30, 2013 | 05:18 AM
  #23
redneck_ram's Avatar
redneck_ram
Im not running the valve guides...
Have you heard/seen my exhaust clip? Its in my build thread. Take a listen!
Old Aug 30, 2013 | 09:46 AM
  #24
Huh? You have valve guides.... probably bronze, pressed into the head. (that would be nice... but, could be just cast iron as well...)
Are you thinking guideplates for the pushrods perhaps?
Old Aug 30, 2013 | 10:56 AM
  #25
snowboundrmk
Ya I actually have your exhaust clip bookmarked lol. I'm trying not to over cam this thing but its tempting.
Old Aug 30, 2013 | 12:06 PM
  #26
aofarrell2's Avatar
aofarrell2
My Odessa heads do NOT have valve guides, if the valves get too loose I have to have the guide bore bored out and a guide installed.
Old Aug 30, 2013 | 12:52 PM
  #27
merc225hp's Avatar
merc225hp
No this thinking is wrong, no extra wear will result in using a little bigger cam with a 1.7 roller rocker.
See above.
Originally Posted by beginningjockey
My Odessa heads do NOT have valve guides, FM. If the valves get too loose I have to have the guide bore bored out and a guide installed.
Valve guides can be repaired to a point, if possible they are knurled then honed to size, if they are past that point they can be pressed out of the head and new ones pressed into the head. I would lay odds that your odessa heads have bronze guilds like 99% of the rest of the heads made have. I can call them if you like to find out.
Edit: I do use push rod guild plates they are used with most other brands of adjustable RR's like the Mopar ones I use.
Old Aug 30, 2013 | 01:51 PM
  #28
aofarrell2's Avatar
aofarrell2
See above.
Sure go ahead and call them, I have the Odessa HD Towing Heads. Note I have the optional hardened valves.
Old Aug 30, 2013 | 02:06 PM
  #29
merc225hp's Avatar
merc225hp
^^^ When I get a chance I will, not the first time I have emailed/called them. So probably after the long weekend I will post my findings right or wrong.
Old Aug 30, 2013 | 05:27 PM
  #30
redneck_ram
valve guides.... guide plates..... eh whatever hahaha
