I decided not to get a regrind cam so I think I found the one I want. The specs are just like rednecks except it has .512 lift instead of .480 but when you calculate the the .480 with a 1.7 rocker that puts it at .512 so I'm gona go with the .512 cam with 1.6 rockers. The lsa is also 112 instead of 114 but I read that helps with torque. RPM range is 900-5200 http://www.summitracing.com/parts/cc...rder=Ascending
Awesome. That is the same cam I was planning on getting here soon. Looks like this build is identical to my build, minus my M1 intake.
Pass on the used parts stick to new stuff. I would post the link to the ad but as per rules posting links to other forums is a no no. Can you step up the the RHS heads? I would skip the 2.02 valves stay stock size and step up to the RHS heads or add some mild porting to the iron rams. I thought Harlands where like $300? I take it you are shopping at H****s site, I will go see what he is offering these days so I am up to date.
Got bored and found this video. I'm not sure if he is a member here, but this is the same build except his motor was bored .030 over. Iron Ram 2.02 heads with the same cam you mentioned earlier. I think he has a Hughes manifold too.
