V10 Can't even turn the tires!
Old Aug 29, 2013 | 04:16 PM
  #21
Johnn123's Avatar
Johnn123
On the rear diffs, any gear for the 9.25 will work, on the front diff, just need to get thick cut gears if you go numerically higher than 4.10.
Would it not be 60's? I thought v10's only came in 3/4 ton up?
Old Aug 29, 2013 | 04:18 PM
  #22
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
V10's had D60/70 combo...
Old Aug 29, 2013 | 04:23 PM
  #23
Ooops. Quite right. Guess I was still stuck on another members Off Road Edition.
Thick cut gears will still work in the front though. Might work in the rear too, but, if you had a posi, and needed to rebuild it, would have to yank the diff, as you wouldn't be able to get the cross pin out with the ring gear in place.
Old Aug 29, 2013 | 06:31 PM
  #24
Jigabop's Avatar
Jigabop
I don't think the V10's ever came with a D80 rear as I believe that is cummins manual trucks only, but if they did: you would need to change the carrier to re-gear it as they use a different carrier for 3.73 or higher (like 3.54), and 4.10 or lower (like 4.88). if it is a 60/70 combo, than no carrier change is required.
Old Aug 29, 2013 | 07:28 PM
  #25
dodge dude94
Going on memory here, the V8's only got the D60 rear, V10's and Cummins autos got the D70 and the Cummins sticks got the D80's.
At least if I'm remembering correctly.
Old Aug 29, 2013 | 08:53 PM
  #26
KasperR34's Avatar
KasperR34
Am I the only one thinking "why should OP need to be spinning the tires" and then lecture him about maturity and safe driving habits?
Old Aug 29, 2013 | 10:33 PM
  #27
aofarrell2's Avatar
aofarrell2
The lecture should be more like a warning about being safe, but spinning tires, there's nothing inherently wrong with that.
Even I do that occasionally.
But a V10 should be able to smoke tires with ease, if it can't something IS wrong with it. I see V10s spinning tires all the time around here.
Old Aug 29, 2013 | 11:27 PM
  #28
dodge dude94
Because sometimes, you just need to see how much torque an engine can put to the ground.
I shouldn't have replied, but I did.
Old Aug 30, 2013 | 03:26 AM
  #29
KasperR34's Avatar
KasperR34
But sometimes, My chest spins my 35"s to a crisp
Old Aug 30, 2013 | 11:49 AM
  #30
Jigabop's Avatar
Jigabop
spinning tires is easy as pie
