1995 1500 5.2 making ticking noise.
Old Sep 1, 2013 | 05:30 PM
onekillertb187's Avatar
onekillertb187
Default 1995 1500 5.2 making ticking noise.
The truck hasn't ran for a while, but I got it running again. It is making a ticking noise that is coming from both sides of the motor. Sounds like it is coming from under the valve covers on both sides. Any ideas of what it is, and how I can fix it?
Old Sep 1, 2013 | 05:58 PM
Lifters not pumping up? How's the oil pressure?
How long has it sat?
Old Sep 1, 2013 | 07:44 PM
Purple 92 SS's Avatar
Purple 92 SS
sounds to me like the hydraulic lifters need more oil. if it been sitting for too long it is possible that they are underoiled, and thus make a rattling what not.. the more you run it the more they should quiet up unless theyre stuck... / seized up.
Old Sep 1, 2013 | 08:22 PM
QuadCabLuv's Avatar
QuadCabLuv
^^^ ditto. Change the oil and drive it, if they dont quite down then try some thinner oil. as long as its not missing then they should pump back up.
