FireDodge's 360 Build
Old Jul 15, 2014 | 03:02 PM
  #141
redneck_ram's Avatar
redneck_ram
if you can find a set of red injectors from an 01-03 5.9 get them, would be cheaper, and they run 23.6lbs/hr. you will need ev1-ev6 adapters.
quoted from my pm with merc225hp, and drewactual
Originally Posted by drewactual
Quote:
Well long time since we last spoke, hope you are doing well and enjoying your new ride.
So redneck_ram has a set of those red injectors, same ones you had. I found some old posts of yours about your truck and those injectors. If I read your posts right did you not have issues with those injectors? Any insight would be great. If I remember right Bosch 0-280-155-934.
Thanks Mark
you got it.. no problems whatsoever with those injectors.. I wish I would have stayed with them instead of attempting to 'upgrade'... that effort led to finding the dang clasp to pandora's box, and the reason I know way too much about injectors..
they are NOT four hole sprayers, but it doesn't really matter because at OE fuel sync of 0* on an oe cam, they hit the back of a hot valve to improve atomization (and also cool that valve off, but I think personally that was a later discovered advantage).. they spit 248cc of fuel per minute IIRC, and are rated at 23.6#.. they were stock in '01-'03 5.9's planted in Ram's.. the duty cycle won't break 80% @ WOT, which gives -some- breathing room in the case he does anything with displacement or boost.. it should be a plug and play set up that will work just fine for him..
Old Jul 15, 2014 | 03:32 PM
  #142
FireDodge's Avatar
FireDodge
Thanks Mark
Ok, I could try to find some. But Sean told me this:
"You want 24# at 39psi so it'll be like 27# at your 48psi pressure. Talk to hi-potek.com"
So I figured I'd listen to the guy tuning my engine. But I'm up for cheaper!
Old Jul 15, 2014 | 04:02 PM
  #143
snowboundrmk's Avatar
snowboundrmk
Sounds like you need injectors from a 94-95 5.2 or 5.9 Part # 53030262. They flow 24.6 at 39psi which is 27.3 at your 48psi.
Old Jul 26, 2014 | 12:22 AM
  #144
FireDodge's Avatar
FireDodge
I don't feel like posting a new thread, but I have an opportunity to purchase a 95 Dodge 3500 with the 12 valve. 180k, Hx35?, 191dv's, 215hp injectors, and a very well built auto trans and transfer case. Its a friend's of mine and I can grab it for 3000. Downside is that it has bad blowbye, and needs rebuilt. Upside is that the friend I'm buying it from will actually repair it for me. He took the duallys off and made it to a single rear. Club cab, long bed. I planned on also getting studs before the repairs. I kinda really want it
Old Jul 26, 2014 | 12:33 AM
  #145
Derick C.'s Avatar
Derick C.
I would jump on it. Cummins is the way to go.
Old Jul 26, 2014 | 12:51 AM
  #146
FireDodge's Avatar
FireDodge
It books for 8-10k in good condition.
Old Jul 26, 2014 | 01:10 AM
  #147
tincan57's Avatar
tincan57
^Good buy.................like those injectors
Saw this tonight near Lexington KY 95 3500 4wd no blowby 2k posted 13 hours ago craigslist ----old guy wrecked front bumper, hood, bent frame horn. Pulled the motor but sounds like he put it back in selling as a runner............auto that shifts out (he had it 4 days ago 2,500). K.
Last edited by tincan57; Jul 26, 2014 at 02:07 AM. Reason: spell/CL for FireDodge if need cl list# pm me
Old Jul 26, 2014 | 01:46 AM
  #148
FireDodge's Avatar
FireDodge
The trans has only 200 miles on it because he started digging into the motor right after. Billet torque converter and a bunch of other goodies mostly for towing.
Old Jul 27, 2014 | 12:55 AM
  #149
tincan57's Avatar
tincan57
You're going to appreciate having both options. Looking forward to full Ops. K.
Old Jul 27, 2014 | 12:56 AM
  #150
Wh1t3NuKle's Avatar
Wh1t3NuKle
Get it FireDodge!
