What do you think I could realistically get for this?
Old Oct 19, 2013 | 11:51 AM
Girly TT's Avatar
Girly TT
Default What do you think I could realistically get for this?
1996 Ram 2500 V10
Recent mods (all less than 10k miles, most less than 5k)
Borgeson Steering Box
Borgeson Steering shaft
Steering column
Control Arm Bushings
Control Arm Bolts
Dual steering stabilizer Kit
fancy blue boots for steering stabilizer
Power Steering lines
Power Steering Pump
Power Steering Pump Pulley
Water pump
Oil pump gears
oil pump cover
timing chain cover
timing chain cover gaskets
valve cover gaskets
upper and lower intake manifold gaskets
oil pan gaskets
powder coated upper and lower intake manifolds, valve covers, and brackets
spark plugs
headers
custom exhaust w/x-pipe and dual cats
Oxygen sensors
Coolant temp sensors
Cam sensor x2
Connecting rod bearings
Crankshaft bearings
Rear main seal
Acc belt auto tensioner
Acc belt
transmission cooler lines
air filter
PATC Stage 3 Mega Viper trans rebuild kit
Labor for Trans rebuild
Derale Deep Trans Pan
Derale trans filter extender
Machining for torque converter
universal joints for front drive shaft
universal joints for rear drive shaft
carrier bearing for rear drive shaft
4.56 ring gear set for rear differential
Rear differential carrier
Rear differential bearing kit
Bilstein shocks
Hummer H2 wheels w/tires
Crossfire seats
Carpet
Windshield
Rear sliding window
Door belt moldings
Door/Tailgate handles
Rocker panel, driver side
custom inner rocker panel
floor board, driver side
sheet metal for driver side floor board and passenger side
lower cab corners (driver and passenger side)
wheel arch, driver side
door hinge rebuild kit
POR15 chassis paint, 1 gallon
front inner fender covers
rear bumper w/cover and brackets
front bumper plastics and fog lights (not currently used)
99-01 Sport front bumper
sport fog lights
Sport grille and bracket
Regular grille and bracket (not currently used)
head lights
HID's for fog lights
headlight rewire kit
headlight switch
bed liner
starter
power wire to starter
ground cable to engine
battery
battery tie down
tail gate cables
dodge ram steering column bushing
Timbren rear suspension helpers
clearance lights
3rd brake light
one replacement tail light
rear LSD clutch kit
nerf bars
Trailer rewire
Trailer brake controller
Ball joints for front suspension
wheel hubs, front
track bar
1 ton chevy rear wheel cylinders
rear brake shoes
rear brake line
rear brake drums
front brake pads
refinished front rotors
2 new tires
spark plugs
front differential carrier
4.56 gear set for front differential
differential bearing/seal kit
rebuilt front driveshaft
PSC power steering pump
Power crossfire gray leather sport seats (driver and passenger), interior converted to all black (dash, panels, carpet, etc), Completely restored body (no rust), and entire frame coated in rust preventer (POR15), rebuilt EVERYTHING.
We had a baby about 6 months ago, and not having a rear door is going to be difficult, nevermind we just haven't used it in over a year... Just wondering if it's worth even bothering to try to sell it.
It has hauled halfway across the country and back dozens of times, it's a towing champion.
Thoughts?
(when we first bought it....)
Attached Thumbnails What do you think I could realistically get for this?-1382089_10152337845468266_1823283358_n.jpg
Old Oct 19, 2013 | 11:55 AM
I doubt you will get what you invested out of it. It IS a NICE truck. (understatement) The lack of rear doors will only be an issue for a little while, then your new addition to the family will be asking for the keys, not being plopped into a car (truck?) seat. If it's paid for, and doesn't need to be a daily driver, and you have the room for it, just keep it.
How much would you *like* to get out of it?
Old Oct 19, 2013 | 12:01 PM
Girly TT's Avatar
Girly TT
We wont get CLOSE to what we invested, just wondering what peoples thoughts were as to what we MAY be able to get for it.
It's paid for, isn't driven really at all because it's just not practical. We bought an SUV and can tow a single car with that and have plenty of room inside for the baby and all of his accessories, so, this just sits...
Old Oct 19, 2013 | 12:02 PM
Girly TT's Avatar
Girly TT
I have no idea what we would want out of it, I haven't been able to find anything remotely comparable out there to even gauge a price off of. LOL
Old Oct 19, 2013 | 12:08 PM
Maybe you could just *loan* it to me then. At least it would get some use.
Pricing it out on various "value" websites, I come up with a little over 4K. Bear in mind, I didn't get an option for the 8.0 motor. Even so, that strikes me as painfully under priced. Around here, probably 8 to 10K without too much effort.
Old Oct 19, 2013 | 12:22 PM
Girly TT's Avatar
Girly TT
Yea, it's not really a book value kind of truck LOL
Old Oct 19, 2013 | 12:28 PM
BBartow's Avatar
BBartow
+1 here as well.
Old Oct 19, 2013 | 02:10 PM
ChillyPhil's Avatar
ChillyPhil
That's one sharp looking truck! Just curious, what are them things under the front of the truck? Are they to aid the steering?
Old Oct 19, 2013 | 02:15 PM
clipper77's Avatar
clipper77
One of the best looking 10's I've ever seen.
Throw it up on CL for what you think would be fair and go from there.
Worst thing that happens is you say no to a few people.
If you have receipts of all of the work you have done to it, that can only help your cause.
Old Oct 19, 2013 | 02:36 PM
BBartow's Avatar
BBartow
I thought it was for a plow or something.
